The Gotts Intake with pics
Old Mar 4, 2010 | 03:36 PM
  #271
FlashmasterK's Avatar
That was stupid easy.
FYI- no silencer on a 2007 4.2L
1. Gotts2BMe
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
Old Mar 4, 2010 | 03:41 PM
  #272
Veteran: Army
glad it works on the newer V-6 trucks...
Old Mar 4, 2010 | 03:54 PM
  #273
Will let yall know of any improvements noticed on the newer V6's. I am waiting on the reset w/ battery disconnected.
FYI, on the newer ones, dont worry about pipe color, because you cant even see it.
Old Mar 4, 2010 | 06:56 PM
  #274
Scott011422's Avatar
66 people have done this mod and not one has responded on what it did to their fuel economy?
Old Mar 5, 2010 | 12:21 PM
  #275
I have been playing around to see about power, acceleration, response etc. improvement. I think there is a difference and definately worth the $15 and 30min it took to do.
Once I get back to driving it normally, Ill see what it does to MPG's but right now, Im playing around to much to get an accurate reading!
Old Mar 5, 2010 | 08:26 PM
  #276
Gotts2BMe's Avatar
The only way an intake mod will improve economy is when it leans out the air to fuel ratio. Your pcm is set to run the vehicle at a certain A/F ratio and should correct your A/F ratio from the added flow via the intake mod or any aftermarket intake.
Old Mar 6, 2010 | 02:18 PM
  #277
MikeChris2's Avatar
I just tried this mod on my 99 and it won't run more than 2 seconds after starting. I put it back to stock and reset my pcm again. The manual says it might need driven, so i drove it for a couple minutes and it runs horribly. Please tell me my truck isn't messed up! Should i reset again or just drive it some more and cross my fingers?
Old Mar 6, 2010 | 06:17 PM
  #278
scruffy's Avatar
No, you probably haven't seriously messed anything up. If your truck wont run for more than two seconds it sounds like the idle air control valve isn't working or isn't getting air. Either that or you have a massive vacuum leak somewhere. Go through and check the entire intake assembly to see if you have any leaks or if you forgot to connect a hose or sensor.
- Erik
BTW: Did this mod around 5 months ago, no problems, and immediate increase in throttle response. GOTTS Mod FTW!
Old Mar 6, 2010 | 07:18 PM
  #279
MikeChris2's Avatar
Ok now I feel like an idiot. One of the 3/4 inch hoses near the throttle body came off. It is kind of a loose fit and doesn't have a clamp. So I must have bumped it or something. Since i noticed that I re-installed the mod. Instead of unhooking the battery I just took out the PCM fuse the left it out while i cleaned out my garage (it was a mess). Put the fuse back in and WHOA BABY does is work. Took a test drive, got it to around 55 on the highway then "goosed" the gas. It pushed me back in my seat. Thanks for the great Mod and put my name on the already long list.
Old Mar 7, 2010 | 04:21 PM
  #280
tja349's Avatar
just did the mod today super easy u cant see the pipe on mine either so color wasnt a big deal.. i had painted the white pipe black but not needed i was going to check out the silencer but i dont think there is one on the 98 4.2s anyone know for sure? and also about how far should the pipe go into the hole? i went about an inch seemed like enough
Old Mar 7, 2010 | 09:22 PM
  #281
Rojo024's Avatar
'08 4.6L 2V done. Better throttle response for sure. Super easy.
1. Gotts2BMe
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
67. Rojo024
Old Mar 8, 2010 | 06:19 AM
  #282
MikeChris2's Avatar
1. Gotts2BMe
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
67. Rojo024
68. MikeChris2
Old Mar 8, 2010 | 06:26 AM
  #283
sean46's Avatar
Did mine last weekend. Best $10 I ever spent! Much better throttle response! If you havent done this yet, you need to.
1. Gotts2BMe
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
67. Rojo024
68. MikeChris2
69. sean46
Old Mar 9, 2010 | 11:24 AM
  #284
CGpinoy's Avatar
New to the forum...glad I found this mod! cheap-n-awesome..........
1. Gotts2BMe
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
67. Rojo024
68. MikeChris2
69. sean46
70. CGpinoy
add me to the list...
Old Mar 10, 2010 | 02:32 PM
  #285
Tommer's Avatar
Hey, Gotts. Did you mod, with the silencer removal and K&N dropin filter. Best thing I've done to my truck! I never tire of the immediate response every time I step on it. I've tried adding my name to the list, but it doesn't show up. Is there a way to add my name? Thanx.
