X pipe w/ true duals
Old Aug 9, 2007 | 07:11 PM
ws6_guyscrew's Avatar
also small note, when you cant find an X pipe online anywhere you can always have the shop custom make it out of 2.25" pipes for a precise fit
Old Aug 10, 2007 | 12:35 PM
Ford Truckin''s Avatar
Magnaflow x pipe dimensions?
Does anyone know the center-center dimension on the Magnaflow X pipe? The product description is:
2.25'' Inlet I.D.
Dual Inlet/Dual Outlet
2.5'' x 4'' Center Core
12'' Length
Stamped Stainless Steel. I didn't know if the 4" center core was the center-center dimension.
Old Aug 10, 2007 | 03:57 PM
openclasspro#11's Avatar
i have the above pipe- 4" c to c-phil
Old Aug 10, 2007 | 04:05 PM
Appreciate it Phil. I thought I would measure my existing true duals and see their spacing about where the x pipe would go. I don't want to spend the money for rerouting the pipes to fit the x pipe. You know what I mean.
Old Aug 11, 2007 | 08:32 PM
fordboy05's Avatar
Heres mine:
https://www.f150online.com/forums/sh...d.php?t=296853
Before the X pipe, My truck just had a deep obnoxious rumble. Now, it has more "tone" and a smoother sounding exhaust. I like it..
Old Aug 11, 2007 | 08:43 PM
Kevin24's Avatar
Originally Posted by fordboy05
Heres mine:
That sounds good,nice and deep
Old Aug 12, 2007 | 11:38 AM
thebigbc's Avatar
I found a site that sells the x pipes pretty cheap: http://moesperformance.com/index.php...roducts_id=993
free shipping too. I think I am going to do just straight pipe with either 2" or 2.25" all the way back and just have one of those welded towards the front somewhere.
Old Aug 24, 2007 | 02:35 PM
buckhunter1's Avatar
xpipe
I would like to do a x-pipe also, should it be placed close to/or farther away from the cats. Also will it make a difference in gas milage? a friend added cat back duels and it seemed to hurt his gas mileage- he doesn't have a x-pipe though?Thanks
Old Aug 24, 2007 | 05:58 PM
MudTerrain's Avatar
You want your x-pipe as close to the exhaust manifolds as possible. Yes, right behind the cats.
A properly placed x-pipe & exhaust should increase gas mileage. Does your friend have true duals or just a y-pipe dual exhaust?
