Any drawbacks of cutouts?
do cutouts have any drawbacks, b/c from what ive been reading they just give that straight pipe sound when put in front of the muffler, and increase airflow. does it suck on the gas or anything? what are the pros and cons?
1991 Ford F-250
460 7.5L
70series Flowmaster system
K&N
3in Lift on 35" OpenCountry on 17s
1991 Ford F-250
460 7.5L
K&N
None that I know of...although I hear they are pretty loud, but unless thats a problem. However I doubt that cause thats probably what you are looking for.
I'm not sure if inspections will give you a hard time though, unless you don't them?
i was also wondering if there were problems with the electric cutouts...i take my truck offroad and im not sure if there would be any problems with anything stopping working. i also heard that there were some problems with the manual...anyone got anything on these?
Originally Posted by GreenDragon
i had another question too...if i got the manual cutout, could i just mount an electric on to that? cuz most the electrics i've seen seem to be just covers for the y-pipe...
so the electrics don't leak at all? it seems that they might for some reason...and what if it stops working for some reason, has this been a problem for anyone? cuz from what I here these things are perfect.
There will always be the possibility of leak issues with electric cutouts due to the motor/butterflies failing. I've heard some brands are more reliable than others though.
so im thinking that going with a manual cutout might be the way to go since i go offroad, its cheaper, and i can get a cover for the manual to prevent the leaks with that. unless anyone has any other opinions?.?.
so i keep changing my mind...i just found a heavy duty fully stainless electric cutout...
http://www.jegs.com/webapp/wcs/store...57985_-1_11529
and this doesn't come with the exhaust dump...so the question is does every exhaust dump with the 3bolt pattern fit the electric cutout?
i would def. go with an electric..try here http://badlanzhpe.com/index.html its where i ordered mine from..Its the cheapest that i could find but the quality is still good..and the customer cervice is great
i went with a manual right before the muffler. If you have a credible exhaust shop fab you one up and use gaskets there should be no problems with leaks.
In my opinion electric cutouts are a waste of money unless you buy the ones that are 300-400 dollars. I had a buddy that had a pair on his C5 Corvette and the motors burnt out after two weeks of use.
I've heard more people having leak problems from their electric cut outs than anything else. I have a manual and I love it. I've had it for about 6 months and no leaks what so ever. I highly recommend the manual because of the price and my personal experience with them. I paid 28 bucks from summit.
