magnaflow tru x muffler?
Old May 10, 2007 | 10:26 PM
built54's Avatar
Originally Posted by openclasspro#11
built 54- thats also available in a shorter length 4x9 as well=phil
Which one is that?
Old May 10, 2007 | 10:51 PM
openclasspro#11's Avatar
under products, stainless steel universal-11379-4x9x17
11386=4x9x20=phil
Old May 13, 2007 | 09:47 PM
built54's Avatar
so the 11379 has that built in X pipe?
Old May 14, 2007 | 12:40 AM
Bartak1's Avatar
Hey built, not trying to steal your post here, but I saw something about this mentioned earlier in this thread.
You or OpenClassPro should be able to tell me pretty well.
On a mostly stock truck such as mine, as far as power (not really a gain in power, but more a loss of power) you dont think going with true duals and the Maggy muffler with internal X pipe would be any worse than a SI/DO maggy muffler?
I would think the true duals with internal X muffler would kill my low end compared to a SIDO setup...? Thoughts?
Old May 14, 2007 | 06:00 AM
tq
i hsad true duals on my 8k lb van before tp tuned it- if i lost low end tq- i'd remove the duals and go back to oem- i used 2.25 and x [ not tin mufflers to have as much tq as possible actually i gained torque- built 5.4 got to magnaflows webpage click on trucks, universal mufflers all specs are there both the mufflers i listed have x's in them-phil
Old May 14, 2007 | 07:11 PM
Bartak1's Avatar
So you used an X pipe as far forward as you could, then used two mufflers, one on each side, correct?
Thank you sir
Old May 14, 2007 | 07:22 PM
Kevin24's Avatar
Hey Bartak,That is exactly what i am doing in the next week.I have flow 40s right now and they are terrible.I am using 2 1/4 pipe w/ 2 14in round magnaflows.One for each pipe.I hope it works I will let ya know if you want.
I got mine for $100 for both from www.performancepeddler.com
Old May 14, 2007 | 10:21 PM
Thank you sir
yes see my gallery-phil
Old May 14, 2007 | 11:19 PM
Bartak1's Avatar
Sounds great, I would love to know how it turns out.
Openclasspro, thanks for the clarification.
Old May 18, 2007 | 04:47 PM
Kevin24's Avatar
Allright guys they're on!!!!I have only put 50 miles on it but here's what i think.At take of it has a deeper tone than the flows did A smoother and throaty sound.Everyone that has heard it says it louder than it was before.At about 60-70mph its not very loud so good there.At speeds from 75 up gets really loud while cruising so that may not be good for long trips.The other thing is in the upper RPMs it remains very deep and does not cackle like the flows did.Seat of pants feels to have picked up low end power and mid range over the flows.All in all i am pretty happy with the sound of them I honestly think they are just as loud or louder than the flows.The flows still were louder way up in the RPMs though.It's friggin loud and sounds great!!!
Bartak,depending on how loud you want you may want to think about the 18in
Built54,i think your truck would sound great with your headers and cats but the 14s may be to loud w/ your set up.You may want to try that longer X-muffler or a longer round one
Edit.....Definately more power.It spins the tires easily now.Never would with flows!!
If i had it to do over again i would try the 18in,for a little less noise
added pics to album
Old May 20, 2007 | 05:48 PM
Bartak1's Avatar
Looking good, thanks for the review.
I might try a 2.25 inch setup with X pipe.
Not sure about mufflers. My last pickup had true duals with 12 inch glasspacks...I would THINK my older one would have been louder, but I dont know. I like to know its there, but I dont like overly loud...living in a small town everyone (including the cops ) know exactley where your at with overly loud exhuast..which isnt good for me!
Would you happen to have any sound clips or anything Kevin?
Thanks!
Old May 20, 2007 | 06:02 PM
Kevin24's Avatar
No problem,i will add a x-pipe soon also.I don't know of anyone with a newer ford running true duels?It is way louder than i expected,which is cool but sucks on long trips.I can prob do a sound clip,what does everyone use for making a sound clip one easily?
