K&N or AEM
K&N or AEM
I am going to get an air intake for my truck. I want something that gets me better gas mileage with more horsepower. I am thinking about getting either a K&N or an AEM. Which one is better in your opinion? Also, where would be the cheapest place to get one of those? Thanks for the help guys.
Well your not going to find a clear answer here. Intakes are mainly perference...
K&N
Pros- Cheapest of Intakes
Cons- Have to Oil the Filter
AEM
pros- Oil Free filter
cons- More expensive than the K&N
K&N
AEM
you still have to clean the AEM filter, but you do not have to oil it. They give you a cleaning solution that you dip the filter into and let it dry. After that you are good to go for another 5-10K miles depending on how much you take it off-roading. The AEM is a good intake, I like it better than the K&N I had before. I like having the peace of mind knowing that I do not have to oil the filter. Performance wise the difference between the two is negligible. Any intake is better than the stock IMO.
Dont worry about oiling a K&N Ive got um on my car and my truck my car has been 33K+ (installed when new w/49mi) and Ive never even taken it off.
The truck I just installed it recently but they are good for 50K+ depending on conditions b4 clean and reoil. Definetly well over 10K even in the dustiest places.
The mileage gains are minimal - perhaps 1 mpg at the most. Your best bet to increase mileage is to keep your foot out of it. With cruise control on flat land doing 65-70 mph I've been as high as 18 mpg. With my foot in it I can go as low as 12 mpg in town though, so it's more how you drive it than what intake you have...
I agree a properly maintaine K&N is the way to go aem is still ur basic restrive filter design just improved a little K&N uses oil to remove dust and is less restrive better airflow
You can put a pre-filer on the filter and go even longer between oilings/cleanings
http://www.outerwearsracing.com/splash.html
Plus they repel water...wet filter = bad
plus these things take away the hiss sound away from the intake
It makes your engine run more effeciently... So more effecient = more power and better gas milage..
However, the better gas milage only comes if you are not steping on it using that extra power.
I haven't needed to oil mine yet either
