Exhaust Ideas + MA exhaust laws
Old Aug 15, 2006 | 10:59 AM
  #31
UWANSUM's Avatar
Originally Posted by Fordwitflows
So, Sounds like I made my decision. Change to IMCO muffler and change to hi-flow cats. Wat are the best hi-flow cats out there?
Go with magnaflow cats. Too bad for emissions...you could go no cats and a bullit blow-through muffler. That would be some obnoxiosially loud noise. Your neighbors would love you.
Do you see my signature...because I can't.
Old Aug 15, 2006 | 11:04 AM
  #32
UWANSUM's Avatar
test
Old Aug 15, 2006 | 11:07 AM
  #33
Fordwitflows's Avatar
thanks-
no should i jjst switch from the imco to the flowmaster and leave it at si/do the back. Or should i get two imco and run true duals? wat would be louder?
will i have enough back pressure if i go true duals
ps-cant see your sig-make sure your clicking show ur signature at the bottom evrey time
Old Aug 15, 2006 | 11:13 AM
  #34
UWANSUM's Avatar
thanks-
Thank You for sig advise...I'm kinda new to this.
The best sound that I had out of my 4.6L was borla exited out the right side in front of the tire. It looks bad *** too. Same place as my current truck. The best part is the echo off of other vehicles. If you get a 30MPH guy in a 50 Zone...You can really let him know he is not moving fast enough.
Old Aug 15, 2006 | 11:20 AM
  #35
Matts_fx4's Avatar
Heres an idea... either go with glass packs or straight pipes. That will be loud. End of story.
Old Aug 15, 2006 | 11:22 AM
  #36
UWANSUM's Avatar
He must pass emissions....
Old Aug 15, 2006 | 12:28 PM
  #37
Should I leave my pipes alone and just switch from flowmaster to IMCO. Or should I go true duals with two IMCO mufflers
Old Aug 15, 2006 | 12:31 PM
  #38
Should I just leave my pipe aalone and switch from flows to IMCO si/do one muffler. Or should I go hi-flows and run true duals with the imco mufflers. What would be louder? Will I lose any low end power of I go true duals and hi-flow cats
Old Aug 15, 2006 | 01:39 PM
  #39
UWANSUM's Avatar
Damn Witflow..... Just fkn cut your pipe before the rear axle, fit IMCO in, Attach the **** with some good bandclamps, rig up some....wait....just make it look kinda like this:
Sorry about the size.
Old Aug 15, 2006 | 01:47 PM
  #40
I want to keep it dual out the back. I am debating if i should go si/do one muffler. Or run true duals with two muffler.
Wat would be louder?
low end loss with true duals?????
Old Aug 15, 2006 | 01:48 PM
  #41
UWANSUM's Avatar
Nevermind....the size is ok.
Old Aug 15, 2006 | 01:51 PM
  #42
desi_rico's Avatar
Originally Posted by jjmIII
I'd get a Maganaflow single-in/single-out cat back.
Read this:
http://www.troyerperformance.com/cgi...atalogno=15609
But buy it here:
http://www.hottexhaust.com/Ford_Truc..._Magnaflow.htm
Use coupon code "jetta" at checkout for a nice savings.
Thanks for the info. There is something about dual exhaust that I really like so I think I'm going to go dual
Old Aug 15, 2006 | 01:55 PM
  #43
UWANSUM's Avatar
Go true duels for sound and as long as you keep the cats your backpressure will be fine. You will not lose any low end torque (nothing you will notice). No more questions about exhaust. This is the most I've ever talked about mufflers on a stock mod motor. Ask about a supercharger or something that will REALLY make a difference.
Old Aug 15, 2006 | 02:23 PM
  #44
even with hi-flow cats. True duals will be louder??
PS-Trying to get evreything right before I invest
Old Aug 15, 2006 | 02:29 PM
  #45
UWANSUM's Avatar
Even with high flow cats. If you want to take the exhaust out the back, true dual is the way to go....buy IMCO. invest brotha. I've already went through 3 different mufflers on mine and two at once at some point. Anything sounds good on a Mod motor. I don't think you will be dissapointed.
