Need a new exhaust for 5.0
Old 06-03-2006, 11:50 PM
gibson1's Avatar
I have an 89 f150 with the 5.0 engine. Currently I am running the exhaust with no cats running into dual 12in glasspacks. I want something louder. It seems as though the truck is getting quieter. I had a 95 dodge ram with a high flow cat and straight pipes and that truck roared. Should I cut out the glasspacks and run straight pipes all the way back or use some type of flowmaster or other high flow mufflers to get a better sound?
thanks
Old 06-04-2006, 11:42 PM
slow150's Avatar
i like the way magnaflows sound on the 5.0....i had some on my truck...then i pulled a transam and botomed it out and riped them off... it's got a low rumble at idel and then a roar at higher rpms
Old 06-10-2006, 12:12 AM
gibson1's Avatar
I have found out that the glasspacks on the truck are like 8 years old. If I put on some new ones I should get back the loudness. Is there anything smaller than a 12in glasspack?
Old 06-10-2006, 02:14 PM
Peacemaker's Avatar
Dynomax bullet mufflers are pretty loud.
Old 06-10-2006, 05:06 PM
Mstraus9's Avatar
If you get a 12 inch glasspack and put it on backwards it will ROAR!
Old 06-10-2006, 11:01 PM
gibson1's Avatar
Will it hurt the trucks performance having a glasspack on backwards? Also, how does being backwards make a difference in sound?
Thanks.
Old 06-11-2006, 11:15 PM
Mstraus9's Avatar
If anything it should give better performance...the fins on the inside catch less air when they're backwards making better airflow which in return produces a louder sound!
Quick Reply: Need a new exhaust for 5.0
