crosswiring addon foglights to headlamp switch?
Old Nov 13, 2002 | 01:53 PM
jkingman's Avatar
Question crosswiring addon foglights to headlamp switch?
I have non-stock fog lights and wanted to integrate them with my headlamp switch - I pulled the switch out and there's a receptacle in there with a connector attached...
I looked all through the wiring diagrams that I could find, but I can't seem to trace the harness back anywhere under the hood?!
Has anyone done this? If so, could you enlighten me a bit?
Thanks in advance!
Jay
Old Nov 13, 2002 | 02:53 PM
daniel01's Avatar
hello, i ran into the same problem here is what i found...
-truck was prewired for fogs
-when light switch in truck is in on position (not park) it pulls out to activate fogs (mine did not so i replaced switch 2minutes) see link
http://www.svtlightnings.com/svt/how...s/foglamps.htm
-wires for foglights are at front on each side.. go under truck on passenger side on front and look at horn wires there will be an un-used wire with blue connector that's it and a mate to it is on opposite side (carefull to mind your wattage)
-my original post was
https://www.f150online.com/forums/sh...threadid=96040
hope this helps
Old Nov 13, 2002 | 07:34 PM
jkingman's Avatar
Outstanding! Thank you My headlamp switch *does* have the pull-out for fogs option - same as was on my 99 Cougar. I've looked behind the bumper but didn't find anything - I will check again now that I know they're there someplace
Thanks!
Jay
