Radio And Interior Lts Blinking When Cold
Old Nov 1, 2002 | 09:45 AM
ncfirefighter1's Avatar
Question Radio And Interior Lts Blinking When Cold
Over the past couple mornings I have noticed my interior dash lights and radio lights "blinking" or diming at idle. It only does it for a minute or two after first starting up. Has anyone else seen this problem????? Pls Help...
Old Nov 1, 2002 | 09:52 AM
TexfordD's Avatar
check your fuses to make sure...
they hav'nt worked loose...then check your connections at the battery posts,nows the time to give them a good cleaning...apply a little dielectric grease to the terminals and it will help keep the corrosion at bay
Old Nov 1, 2002 | 12:26 PM
More...
I should have included this...all electric connections are clean and tight. The truck only has 4900 miles on it and I experience no other electric problems. It only happens after the truck starts for about 1 minute (when it's cold outside).
Old Nov 1, 2002 | 02:10 PM
Old Timer's Avatar
Hi NC
Years ago as you may know, that was a common thing. But not common anymore.
Run a charging (alt) out put test including the battery. If you cant do that then you might want to take to dealer. Its underwarranty. Just a guess?
Good luck....OT
Old Nov 1, 2002 | 02:24 PM
ok.
Thanks.
Old Nov 21, 2002 | 10:27 AM
Zerb's Avatar
Flukey Dash lights
I have the same problem - prod date 6/96. All else is fine, but my dash illumination fluctuated at start-up. All dash LIGHTS - not the indicators - finally failed. The thumwheel resistor on the headlight switch was/is shot. Now is the time to think about optioning for the auto dimmers....hmmmm.
