washer fluid warning light
Old Nov 3, 2001 | 07:43 PM
iamhakiem's Avatar
I wish I had a indicator light for my washer fluid cause Whenever someone tailgates me at 70mph I will mist them out by holding the squirt button down for a few seconds. This usually makes them back off. I go through alot of fluid this way but it is worth the laugh. You guys should try it sometime. It only works at high speed though. 70+mph. Enjoy the new trick.
http://f150world.com/hakiem
Old Nov 3, 2001 | 11:55 PM
S-76's Avatar
Angry
Originally posted by Fritzthecat
S76, on my 2000 F150 the 'CRUISE' light comes on in the instrument cluster when the cruise is engaged. No indication when it's on only when it is engaged.
Fritz
Grrrr....
They must have changed it for 2k. Anyone else with a 99 that has a functional c/c or washer fluid lite?
Old Nov 4, 2001 | 04:49 PM
J-150's Avatar
Because there is a place for an indicator in the cluster is by no means an arguement as to whether your truck should have this fetaure or not. All 2wd trucks have 4x4 indicators and water in fuel and wait indicators.
Dammit, for my 40,000 I better get deisel and 4wd!
And robstaxi, 155,000 in 46 months constitutes driving my truck. Do you drive yours? I guess you do, you're just too lazy to check your oil level on a regular basis. Then your engine blows and you slam Ford and go on about how you're buying a Chevy (as you have indicated a Chev bias in one of your posts)
Oh and Orangville is not so far north that your 4 litres of ww fluid should last a couple of weeks.
