Wire harness for 2012
Old Jul 8, 2018 | 04:14 PM
strech46290's Avatar
I went to hook up a 7 pin trailer harness and found my harness broke. Can someone provide a part number to replace this wireing harness. It goes from the rear of the truck to the front . I'll attach a few pictures. Thanks.
Old Jul 8, 2018 | 04:23 PM
Old Jul 8, 2018 | 04:26 PM
Are you looking for a new connector or the whole harness?
Old Jul 8, 2018 | 04:52 PM
Either one. Just want to hook up a trailer without hacking it up.
Old Jul 8, 2018 | 06:31 PM
Hmm. I looked it up, and it is very VIN specific. I hate to say this, but I'd check with a dealer's parts dept, and get the right part number for your truck. Heck, you can even come back and post the part number here, and one of us might be able to find you a deal on it.
Old Jul 8, 2018 | 06:37 PM
Thanks. I will check with them this week.
Old Jul 8, 2018 | 06:39 PM
Sounds good. You likely won't even need to go down there if you explain it good enough over the phone. Or you can call the quite helpful folks at Tasca. https://www.tascaparts.com/
Old Jul 9, 2018 | 12:18 AM
After looking online I found this diagram. https://parts.ford.com/shop/en/us/wiring-assy-6546721-1
According to it ill need the one labeled 14405 or the end conector that plugs it into 13a576. But i dont have the correct part numbers. Can anyone help here with a solution?
Old Jul 9, 2018 | 10:10 AM
A dealer can look up the part numbers using your VIN.
Old Jul 9, 2018 | 02:02 PM
Local dealer said part number is
Cl3z 14405 fbb
5 day wait and 183.75
Parts guy said no way to buy just the connection have to buy the whole harness. Well I guess I'm going to go look at a few local junkyards but doubt they will have any newer trucks usually only older ones.
Old Jul 9, 2018 | 03:46 PM
Order it from Tasca.
https://www.tascaparts.com/oem-parts...s-cl3z14405fbb
Call and verify with your VIN.
Old Jul 9, 2018 | 03:58 PM
Thanks, I'll be giving them a call.
