2000 f150 died
Old Nov 13, 2017 | 07:24 PM
trevor0714's Avatar
2000 f150 died
i have a 2000 f150 4.6 liter new battery alternator is good all fuses i can check are good have not looked at the starter yet this all started when i was driving down the road at about 60 mph and the truck died completely it would turn over at the time but not start now it wont even try it will just click when i turn the key to start it any ideas would be nice thank you in advance
Old Nov 13, 2017 | 08:04 PM
Will it start with a jump?
Charge and test the battery, test the alternator. Clean all connections from the battery to the starter and grounds.
Old Nov 13, 2017 | 08:45 PM
Roadie's Avatar
If that doesn't fix it, check the fuel pressure. If the pressure is correct, the problem is electrical.
Old Nov 13, 2017 | 09:38 PM
It's electrical if it won't even turn over, it just clicks.
Old Nov 13, 2017 | 11:44 PM
Roadie's Avatar
From his description of what happened he said the starter turned the engine at first and then only clicked which could have been a dead battery. But the engine shutting off driving down the highway could be many things. On this model it's so easy to check the fuel pressure there is no reason not to check it.
