2009 drivers window wont go all the way up
Old Aug 1, 2017 | 02:13 PM
09k6js4x4's Avatar
I have a 2009 crewcab. DS window goes down fine. Window will go up a few inches and stop. Eventually after clicking 100 times it goes up 1/4" at a time. A lot of times if you let it sit(parked) for awhile and come back and try.. it will go up. All other windows work fine.
I took the switch cluster out, but I couldn't figure out how to get the PCB(printed circuit board) out to get to the switches. Any ideas?
I tried to clean them by shotgun spraying with contact cleaner, but still the same. I also checked ohm readings on switches and DS(auto) reading is a bit different. Is there a diode in there? or is this the carbon buildup on the switch?
I reseated all harness connectors.
Has anybody repaired this issue on an '09? What have others done/replaced?
Any help is appreciated.
Old Aug 2, 2017 | 01:44 AM
tbear853's Avatar
Carbon buildup .... my '07 does it.... easy fix .... my '2001 Merc & older FoMoCos naver act up.
Old Aug 2, 2017 | 01:48 AM
tbear853's Avatar
Use this grease on contact that apply "hot".
Amazon Amazon
