Retrofit factory integrated brake controller
Old Oct 15, 2014 | 11:39 PM
chester8420's Avatar
I would like to install a factory integrated brake controller into my 2003 f350. I am aware that they were intended for 2005+ super duties and that my truck doesn't have the pre-wired connections and appropriate master cylinder with brake pressure transducer. But, I was wondering if anyone has a pinout or wiring diagram of the integrated brake controller and adjoining wiring.
I am aware that the brake controller's function is somewhat dependent on input from the trucks computer, because it requires a trip to the dealer to activate it on 2005+ trucks that didn't originally come with it. I know that it requires a master cylinder brake line pressure sensor reading. Maybe if I had a pinout or diagram, I could figure out how to rig it to work with my truck.
SSCULLY made a post years ago about it here:
Originally Posted by SSCULLY
The 2005 SuperDuty uses a brake pressure transducer to the TBC ( different TBC unit ). Not 100 % sure if this stopped on the SD line in 2007 ( most electrical items are listed as 1999-2007 ).The 2005, this was not to the PCM, but direct to the TBC.
If that be the case, then this retrofit might not be that difficult....
Thanks a lot to anyone that might have something.
Old Oct 15, 2014 | 11:45 PM
I added TBC on my new 14 truck.
Exactly what year & model are you looking for as far as the diagram?
Old Oct 16, 2014 | 12:59 AM
Hey man, haven't seen ya in a while... you been doing ok? Is your motor still feeling all that extra power you got from taking the intake silencer out?!! haha
I have a 2003 F350, but I need a diagram from a 2005-2007 super duty with factory integrated tow controller. I need to know the required inputs to the brake controller so I can figure out how to work them out with my 2003 truck. (which "technically" is not compatable)
Old Oct 16, 2014 | 08:45 AM
Shoot me your email and I'll send over some diagrams
Old Oct 17, 2014 | 10:38 PM
Sent. Thanks a lot!
Old Oct 18, 2014 | 04:08 PM
Looks like I'm just gonna have to scrounge around and find a Brakesmart controller. I was already looking for one, but I was hoping that somebody had done this conversion before, or knew where to start with it. Thanks to Patman and SSCULLY.
Old Oct 18, 2014 | 04:22 PM
What's wrong with getting a Prodigy? It's an excellent controller.
Old Oct 18, 2014 | 04:56 PM
Prodigy controllers (and all other inertia controllers) have an accelerometer or pendulum in them, that sense the truck slowing down, and attempt to add trailer braking in proportion to its perceived deleceration. They are jumpy jerky, and they don't always work well. There's a delay between pedal push and the actual brake controller coming on. They sometimes don't activate during certain circumstances such as a slippery road. They can't tell you are trying to slow down if the truck doesn't actually slow down first. Steep hills give them fits. The factory integrated controller doesn't really compare to these kinds of controllers, cause it doesn't work the same way.
The factory integrated controller has a pressure transducer on the brake master cylinder (or abs module). It knows exactly how hard you are pressing the pedal and applies equal braking force to the trailer. Even if the truck is sliding, or there's a heavy load behind, or going up a steep grade, it still presses the brakes on the trailer as hard as you do.
The Brakesmart (and MaxBrake) controllers I mentioned works very similar. They also work by sensing actual brake pressure from a transducer tee'd into a brake line. They are the best, fastest, smoothest aftermarket controller, but the company doesn't build them anymore...
Last edited by chester8420; Oct 18, 2014 at 09:47 PM. Reason: cause I ain't good at usin' spellin'
Old Oct 18, 2014 | 11:31 PM
Just in case anyone else is interested in this "conversion" and why it won't work, this link gives a dumb'd down description of the operating principles of the factory brake controller. It also explains its required relationship to components in the 2005+ trucks that the older trucks either don't have, or differ in operating principle.
http://ww2.justanswer.com/uploads/mu...32301_1121.pdf
I didn't realize how many significant differences there were between the 2004 and 2005 super duties wiring and computer components.
https://www.fleet.ford.com/truckbbas...atsnew2005.pdf
