heated mirrors for 2013 xlt
Old Oct 18, 2013 | 12:44 PM
dogman123's Avatar
I am buying a 2013 xlt that does not have heated rear window or heated side mirrors. I wanted to replace the existing power side mirrors with heated ones. Can I replace the existing ones and use the same wiring harness/plug without additional wires and would I need a switch to control the heat.
Old Jan 1, 2014 | 08:53 PM
Sbradenadams's Avatar
Youll likely need to run new wires through the harness, door, etc and add a fuse and a switch. Doubt that Ford has any of that already run in a truck thats specd with no heated mirrors and windows.
Old Jan 1, 2014 | 08:55 PM
Check your manual and look for a wiring diagram for inside the door. Check and see if its already pre-run by Ford, if it is youll just have to take it from the door to the mirror. But also add a switch.
Old Jan 2, 2014 | 12:09 AM
K.R.newbie's Avatar
I have an 2013 XLT it has no rear defroster but has heated mirrors. The button for it is below the windshield defrost on the a/c panel. Right below it.
