2005 FX4 Tow Harness
Old May 20, 2013 | 05:18 PM
jetpuck73's Avatar
When I hook up my trailer I get all the lights working except the right turn signal, I checked fuse #36 and it is good. It happens on both 4 and 7 pin. What else could it be?
Old May 21, 2013 | 07:06 AM
SSCULLY's Avatar
did you check the fuse, with a meter or test light, from a known good ground to both pins on the back of the fuse while it is installed or the pull and stare method of checking it ?
Did you check the trailer tow adapter with a meter or test light ?
- This is to check and see if there is a problem with the truck or if it is with the trailer.
Old May 21, 2013 | 03:25 PM
jetpuck73's Avatar
The trailer works on another truck. I will test the fuse.
Old May 21, 2013 | 06:41 PM
SSCULLY's Avatar
After you test the fuse, on both sides while installed to a known good ground, test the trailer tow adapter.
