Remove Cigarette Lighter
Old Dec 20, 2012 | 11:43 AM
quickfix's Avatar
I have a '97 f150 and I was wanting to remove the cigarette lighter and put in a USB port in its place. However, I was unsure how to remove it. Can anyone help?
Old Dec 20, 2012 | 11:48 AM
The lighter just pulls out of the power port
Old Dec 20, 2012 | 11:50 AM
Rockpick's Avatar
Moderator &
Moved to ELECTRICAL.
Old Dec 20, 2012 | 12:39 PM
quickfix's Avatar
I meant the socket where the lighter fits into. I want to replace that socket with a USB hub.
Posted from F150online.com App for Android
Old Dec 20, 2012 | 01:25 PM
High-ster's Avatar
Really?? Will that work??
I don't think the power supply coming from a USB2 is 12V.
More like 2.2V.
Seems like a step down converter would be needed.
Maybe someone already makes a custom unit for just that purpose that I'm not aware of.
Old Dec 20, 2012 | 01:28 PM
quickfix's Avatar
I'm only using the hole that is occupied by that. My head unit will be supplying the power.
Old Dec 20, 2012 | 07:06 PM
Generally speaking the metal bucket slides out of the black plastic ring/bucket, then the black plastic comes out.
They make a "puller" tool but its pricey to use only once
Old Dec 21, 2012 | 02:10 PM
JackandJanet's Avatar
Be sure when you do it to cap off the existing wiring and then I'd check that the cigarette lighter fuse is still OK. It supplies power to the OBDII port too, and you wouldn't want that to be dead.
- Jack
