Best place to tap 12v accessory switched on 2012 Screw
Old 03-30-2012, 10:05 AM
SeaRayder's Avatar
I'm currently permanently installing a radar detector permanently in my 2012 Screw. What is the best place to tap a 12v switched source and ground? The fusebox was my first choice but I cant find a bolt to ground to there and the fuses are TINY! I would prefer not to splice a wire, Any Ideas?
-SeaRayder
Old 03-30-2012, 10:14 AM
SSCULLY's Avatar
ATM add a fuse
For the ground, did you check behind the door trim panel.
On the '06 My, you had to pull back on the door trim to find the ground lug, it was not hanging in the open next to the fuse panel.
Quick Reply: Best place to tap 12v accessory switched on 2012 Screw
