looking for pinout for 2004+ window switches
Old Mar 14, 2012 | 11:30 PM
robotprom's Avatar
My passenger window won't move up or down. I tested the window actuator, and when I apply power directly to it with test leads, it'll move the window up and down, so I think I've isolated that the window actuator isn't the problem. I tried switching the passenger switch with a known good switch from the rear doors, and that didn't fix it.
I then cleaned, and when that didn't help, replaced the drivers side switch block. That didn't help either.
So now I'm down to testing the wiring, and I can't find any pinouts for the plug connectors so I can test that the current is getting to where it needs to go.
Does anyone have the pinout diagrams? thanks.
Old Mar 15, 2012 | 06:53 AM
SSCULLY's Avatar
Old Mar 15, 2012 | 10:24 AM
robotprom's Avatar
thanks. I'm assuming I have to jumper the driver's side passenger and passenger side switches to test the passenger side. Is the LB-BK wire the hot power wire?
Old Mar 15, 2012 | 01:51 PM
SSCULLY's Avatar
You will need the driver's side switch installed, to get power and ground on the contacts at the passenger side switch.
that would be test #1, is there power & ground to the other window switch from the master switch.
Old Mar 15, 2012 | 11:12 PM
robotprom's Avatar
I verified that there's power and ground going to the passenger side switch, and power and ground is coming out of the passenger switch on the yel-red and red-yel wires that run to the motor. Guess I'll be pulling the door apart again to see where the fault is.
Old Mar 16, 2012 | 12:40 AM
SSCULLY's Avatar
Did you do the test with the doors open or closed ?
If there is an issue on either door, in the rubber boot to a pillar, it might not show up if the door is open, where when it is closed it does.
Old Mar 16, 2012 | 08:45 AM
robotprom's Avatar
I tested last night with doors closed. I'll try it with doors open before I start pulling the doors apart.
Old Mar 17, 2012 | 11:31 AM
robotprom's Avatar
Ok, so power and ground are going to the plug that connects to the window actuator, but wasn't getting past the female side of the plug connection. I took a chance, cut the plug off, and made a new connector using 1/8 blade connectors and the window works fine now.
thanks for your help!
Old Mar 17, 2012 | 01:52 PM
SSCULLY's Avatar
Don't thank me, thank yourself.
You did all the heavy lifting and diagnoses.
All I did was type 20 words, and click a few times
