Airbag light is on because seatbelt has been tampered with?
ok so i know im pretty stupid already but i read on here that a way i could turn off the seat belt alarm is to look in the seat belt find two white wires and solder them together. now i am getting a blinking code and then a solid from my passenger airbag deactivation light. i am wondering if the reason is my tampering with the two white wires in the seat belt? i am not sure if it is because i recently got a letter from ford for recall having to do with something about the airbag. if anyone knows if the white wires in the belt are related to the airbag light please let me know what you think. besides the fact that im a dumb a**
on
Are you sure there are 2 white wires ?
I checked the EVTM SRS section, and could not find a single white wire in any of it, let alone 2 of them.
Please post the thread on here that had this info.
The way to turn off the seat belt alarm is to program it off, directions are in the owners manual.
If you are going to spit, toilet paper and duct tape it to be off, the seat belt buckle circuit would have been the one to use, adn neither of those wires even has a white in the wire color or stripe, let alone be a white wire.
The PAD is giving a LFC ? Can you post the LFC ?
on
Can you post the thread where you got this info, you posted you read on here.
As posted above, I did not find any white wires in the SRS section, are the wires white only ?
If you are getting a flash code of 5 1 5 1 5 1 5 1 5 1, the LFC is 51, not 30 ( the LFC repeats 5 times ).
I am 75% sure the 2005 LFC table is the same as the 2006, which shows the driver's side belt buckle switch has a short to ground or the resistance is wrong.
Restore the belt buckle switch back to factory install, and use the procedure in the owners manual to turn off the alarm the correct way.
