12 volt problem
12 volt problem
I fried my 12volt in my 07! Any one know where I can get a new one? I can't figure out on Tasca which it is cause there pictures suck. It's the part that plugs into the wire harness behind the dash?? Thank for any info
Huh? Your 12volt WHAT? There are about 130 harness connectors behind the dash, so you're gonna have to be a LOT more specific. Read this thread:
http://www.supermotors.net/forums/th...-and-or-videos
Do you need the wiring or just the socket ?
The parts diagram and listing on Trademotion ( what Tasca and the others use ) is quite clear about which is which ( need to read the name, not just look at a picture ).
#9 is the power point on the dash
Power outlet 04-08 $14.40 $9.50
#12 is the cigar lighter socket.
Socket 06-08 $11.59 $8.92
Prior to ordering you will want to verify your VIN against the part being ordered, send a message from your Tasca Account or call them to confirm.
If you send them a message via your account on Tasca, they can look it up, confirm it and build a shopping cart for you that you just click on the link and fill in the payment / shipping info.
2007 Ford F150 -> Instrument Panel - > Cluster and switches -> { Socket or Power outlet }
The junkyard would be the best/cheapest source for a replacement.
