power windows
the radio work but it is a after market one and he must have it wired on the hot side of the fuse box
yes they do, I'm going to put the door panal off today to check the wirging I just have not had the time to do it, plus it my be why me battery is being drain down
Steve, should the lite blue be hot all the time, mine is hot when the ign. is off, or a bad fuse, I have power on the one side of the fuse box but not the other with the fuse out and no power at the switch but with the fuse in I have power to the switch
my wipers do work with the ign. off could it be a bad ign. switch or maybe they have the actuator rod set wrong in the switch when they replaced it, is that possible
he sure did not know what he was doing, all it took was a little research and a volt meter, now everything works like it should, now all I need to do is fix the power door locks he took out the actuator on the driver side and not sure if there is one on the passenger side I need to remove the panel to see and then replace the window motor on the passinger side, Thanks for all the help P.S. I my need some help locating where the actuator goes, the book I have is junk
