Installing a Rear sliding back glass
Old Dec 16, 2010 | 03:08 PM
znhunter's Avatar
Ive got the motor and the glass I just dont know how to wire it up.Also i am going to need a rear window switch to roll it down and up and i want the OEM look Im pretty sure i have a harness already in the truck for the switch.I have a 2003 f150 supercab xlt 5.4
Old Dec 16, 2010 | 04:29 PM
SSCULLY's Avatar
If you have the harness already, you are doing better than Rockpick did with his '01 back in the day ( he still has the #3 & #4 highest post count threads in this forum, and the 2 highest that are not stickies )
https://www.f150online.com/forums/el...lock-help.html
The wiring is pretty straight forward with the harness, install the switch in the overhead console and plug the motor in, and you are done.
Old Dec 16, 2010 | 09:34 PM
znhunter's Avatar
well now that i think about it the harness is back where the healight switch is.I have fogs lights so its not that could that be the harness for power pedals if it is where would the harness be for a power sliding glass.
Old Dec 16, 2010 | 10:32 PM
SSCULLY's Avatar
I do believe that the power slider switch is normally in the overhead console.
Old Dec 19, 2010 | 09:01 PM
znhunter's Avatar
okay so where do i put the window motor i have a 2003 supercab.And when the window rolls down will it now break?
Old Dec 19, 2010 | 10:39 PM
SSCULLY's Avatar
Rolls down ?
The power slider is the same direction as the manual one, sideways.
Old Dec 21, 2010 | 10:15 AM
Rockpick's Avatar
Moderator &
Hardee har har, Steve. LOL! The dang thing worked (and worked well). HA! HA!
Old Dec 21, 2010 | 10:58 AM
SSCULLY's Avatar
Look at the vast amount of information contained in those 2 threads.
If memory serves me correctly, you were the 1st to go at the CR Lawrence power slider conversion back then.
Here you were calling yourself not leading edge, but being the 1st on the forum to install one
Can I say the "good old days" or is that too close to saying nice gamms
Old Dec 22, 2010 | 10:42 PM
Rockpick's Avatar
Moderator &
We're not getting any younger, Steve. LOL! I'd call that the 'good ole days' for sure... LOL!
Old Dec 27, 2010 | 09:45 AM
kzwierko's Avatar
I had a troubleshooting question on the powerslide rear window. I have a 2001 Lariat and opened my rear window this morning...it worked fine, but when I went to close it the window only closes about an inch and then stops. It will still open back to full open but does not close more than an inch.
I have not had a chance yet to examine the window track, but does anyone have an idea of what the issue could be?
Thanks.
Old Dec 27, 2010 | 11:24 AM
SSCULLY's Avatar
Thanks.
Start with checking the track for obstructions and to make sure it is clean and free of dirt.
Old Dec 27, 2010 | 03:38 PM
kzwierko's Avatar
Thanks, I'll have to check that when I'm finished with work. Worst case, if there is no obstruction could it be an easy troubleshoot on the motor?
Old Dec 27, 2010 | 08:05 PM
rus's Avatar
rus
My first one did that and the cable on the right side broke out of the slider.
Old Dec 27, 2010 | 08:08 PM
rus's Avatar
rus
My 2002 had the complete wiring already installed. All I did was connect the switch on one end and plug the window motor in the other end by the right rear panel. It all works excellent.
Switch wiring is in same location as the power pedals. Both are by the headlight switch. Factory switch goes by pedal switch from factory.
Power motor bolts behind rear seatback. The holes are pre-drilled from factory.
