High power harness
Old Sep 19, 2002 | 09:45 AM
AB's Avatar
AB
High power harness
Hello,
Does anybody know anything if there is a highpower harness available for f-150. I recently installed xenon head lamps with higher wattage and I've been worrying not to fry the housing harness. I asked a question on other forum and that's what I've got.
I have a highpower harness in an Explorer w/80-100 watt bulbs. No problem with the housings.
Your bulbs may not be true 80-100 but put out the same as 80-100 because of the xenon gas. If this is the case, no worries. If not get a harness. They're cheap ($40) and you get a full 12+ volts to the lights which the stock harness in most cars do not.
So Have any one heard anything?
Thanks,
Alex.
Old Dec 27, 2010 | 08:37 PM
MeanGene's Avatar
I have heard some horror stories about the headlight harness getting fried. I think this is what is required. I have the 80/100w on order and also orderd this harness after reading about the issue. I have not installed this yet so I don't know if this will protect our wiring 100%.
