Radio resets itelf at every start up???
Old Dec 13, 2010 | 10:41 PM
montes0908gil's Avatar
hey guys i have the stock 6disc radio on my 06xlt, almost at every cold start and warm start my radio resets to 12:00 and bass and treble levels, is there a problem with my radio or the battery? my cables look clean stock battery since sept. 06 any info would be great thanx.
Old Dec 14, 2010 | 12:08 AM
Jesso's Avatar
Does the truck have a hard time starting like cranking over slowely like the battery is going bad.. i wonder if its possible to have power drop so bad when starting it would cause the stereo. Im not really sure. As far as stereos go they have the B+ wire that supply's power to the deck to keep the memory and the ignition wire is what tells it to turn on. If the B+ wire came undone it could cause the radio to reset itself altho i dont know how likely that is on a stock stereo, i have always replaced mine right away with aftermarket systems.
Old Dec 14, 2010 | 08:52 AM
SSCULLY's Avatar
Not too sure how frequent "almost at every cold start" is.
With it being the factory battery, might want to try a basic check with a meter to see what the level is after sitting over night ( prior to starting )
Also would not hurt to know what the level is after starting the truck ( key from off to start, as soon as the truck is running, turn back to off and check with a meter ).
This is a quick test, and would not tell as much as a real load test on the battery, that is a full charge and apply a load based upon the battery amp specs.
Considering it is not every time, I would not suspect it to be an issue with the KAM fuse ( fuse #31 ) to the radio, that should be a case of all the time if it was blown.
Maybe try pulling and reseating it to see if it is loose in the socket ?
Did you happen to add a fuse to the truck in that slot ?
Old Dec 14, 2010 | 11:23 PM
The truck turns on ok but I do get a sense of possible battery issue since it does it only in 40 to 50 degree mornings and nights,,its the stock radio and i have never messed with the wiring. @sscully i have never added fuses but i'll check the battery with those quick meter tests, thanx guys for ur thoughts...
Old Dec 15, 2010 | 02:10 PM
Barrett's Avatar
It is your battery, I had the same problem last year in my truck. Replaced the battery and the problem went away.
Old Dec 27, 2010 | 12:34 PM
where did u buy your battery from?
Old Dec 27, 2010 | 08:39 PM
rus's Avatar
rus
Same issue here and just replaced battery last week. No more issues with radio now.
