Window Switches problem
Old Aug 3, 2010 | 04:25 PM
carson123987's Avatar
I have a problem with my passenger front window and the driver-side rear window. The switches can roll them down, but not up. From the driver's controls, I can roll them up and down with no problem so it can't be a problem with the motor. The dealer wants to charge me $70 per window to fix them. **** that. Does anyone know how i could fix these switches?
Old Aug 3, 2010 | 08:58 PM
Maverick 15's Avatar
I had a problem with my main window switch with a similar problem. There is a thread on here somewhere that talks about cleaning the contacts on the switch but that only worked for me for about 8 months and then I had the same problem again and then I said heck with it and bought a new switch. Buy yourself new switches that are a breeze to install yourself and you will be good to go.
Old Aug 3, 2010 | 10:04 PM
JackandJanet's Avatar
Read through the Index: https://www.f150online.com/forums/ar...-articles.html
- Jack
Old Aug 6, 2010 | 09:14 AM
PartsChaser's Avatar
Did the fix on mine last night, took me 15 minutes, worked great!! Thanks guys!
Old Aug 9, 2010 | 10:52 AM
Thanks for all the help guys. Maverick do you know where I can buy switches?
Old Aug 9, 2010 | 11:29 AM
I'm not Maverick, but you can certainly get them from a dealer. There are also many online parts distributors, such as Tasca that probably have them.
- Jack
Old Aug 9, 2010 | 08:30 PM
Yep...got mine at the dealer
Old Aug 9, 2010 | 08:38 PM
whackemnstackem's Avatar
op, what year truck you got? mines a 2000 and im having the same problem with my drivers door operating my passenger window
Old Aug 10, 2010 | 09:47 AM
SSCULLY's Avatar
Does the passenger side switch work correctly ?
Old Aug 10, 2010 | 07:41 PM
yeah passenger side switch works fine, only my drivers side switch wont roll up my pass window. happened very randomly
Old Aug 21, 2010 | 11:51 AM
Hoop Cheese's Avatar
passenger side window & both mirrors
Can someone please help? 1999 F-150, for the past two years the passenger side window will not go up or down from either switch and the mirrors would not move to the right. (inside for the driver side and out for the passenger). Both would be an intermintent issue but they have not worked for the past 8 months. Thanks in advance
