Any info on ACTUAL sending units for gauges
Old Jun 15, 2001 | 11:00 AM
XTRUKY's Avatar
Post Any info on ACTUAL sending units for gauges
I am WORRIED now about the sending units for gauges (temp & oil pressure) being simple on/off switches.
With the small radiator and living in AZ, I like to watch my gauges. Plus being a Crime Scene Tech, my truck sits and idles, with the air on just like the squads at the scene's do.
So if anyone knows of after-market sending units, that will make the guages read actually pressures and temps, I would truly be interested in the info.
2001 Lariat SCrew / Oxford White / Sunset Orange Pearl (House of Kolor)
Truck Master Designs FD630-S AirDam, Gibson 9504/Split Rear Exhaust, Fac Moon Roof, 3:55LS, 6CD, Gen III/Beige Buckets, Cab Steps, Slider, Tow, Bed Extender, Bell Tech 2" Shackles, Snug Lid, AirAid
Check out my Photo's at
http://photos.yahoo.com/jeff_east
[This message has been edited by XTRUKY (edited 06-15-2001).]
Old Jun 15, 2001 | 02:00 PM
summitman's Avatar
Post
I was thinking about this yesterday, I hear that the temp and oil senders are just on and off.
I was looking for a noise in the front of my engine so I pulled off the belt and started looking for the bad pully. I started the engine & the phone rang so I went to get it-the truck is still running-when I came back I went to see if the truck was getting warm--the guage was almost pegged. Mine is a 98 so maybe its the newer trucks that are just on & off.
98 f150 4.6 auto 4x4 supercab-short box/bright red & black/6 disk cd changer/ dynomax cat back/k&n fipk/super chip/lund taillight covers/factory fog lamps/Ford mud flaps/pace edwards box cover/ultra wheels/LT265-75-16 BFG/ westin nerf bars/steel horse billit grill & bumper insert/reflex shocks/bosch plat. plus 4/accel wires/auto start/left hand grab handle/2001 lighting headlamp and corner lights/2002 Ski-Doo Summit 800 High Mark X
Old Jun 15, 2001 | 02:24 PM
Norm's Avatar
Post
Temp is real, oil is on /off. Someone else tested the temp with an aftermarket gauge and found that it follows the factory one. Do a search on gauges. Supposedly on Ford-diesel.com they discussed a solution to the oil sender problem but I couldn't find it.
XTRUKY love that paint job, great looking truck! I am leaning towards the truck master designs dam myself.
01 Black XLT 4x2 Screw Gen I, 5.4, Moonroof, 3.55LS, Cloth Captains, Slider, Extender, ClassIII towing, 6 Disc etc.
Mods planned:
Gibson Single Sweptside, AirRaid, Superchip, Line-X bed liner, Fog/driving lights, Tint, Speed grill.
Old Jun 17, 2001 | 08:32 AM
whotnow's Avatar
Post
OK Guys This can't be that hard to fix for us 99-and up owners. If you have ever put your Gauges into test mode you would know what i am talking about. IF 0 means you have oil pressure "put Needle half way UP" and 255 means zero oil pressure "Put needle in low down" , then all we need is to find a variable oil sending unit that shows 0(computer language) as being 100psi. Install That new Sensor, and then find SOMEONE who can REPROGRAM our Gauges To Reflect This!!!!!!!! So What i am saying is all hope is not lost. We Just Need to find that certain SOMEONE who has the resoures to reprogram our dashes!!!! AND A SENSOR
2001 F150-Screw Lariat Gen.# 1
5.4 V8 automatic 4x4
Suppose to have Class III tow package.
Borla Duals out Rear.
K&N Gen #2 FilterCharger.
Moon Roof. 80/100w Headlamps. Fog Lamps. APC Glow Gauge Kit.
Nerf Bars. Edelbrock Oversized Throttlebody.
Fog Light Mod.
Accesory Delay Mod.
Old Jun 18, 2001 | 08:27 AM
Norm's Avatar
Post
The sensor would need to be a variable resistor that generates the linear values needed or in conjunction with a resistor in series. If any one has any experience with different oil sensors let us know. The sensor that is in the truck now is a switch. They do not "speak computer", there is an A/D converter in the ECU to take the resistance change and use it in its calculations or send to the dash.
