mod: low beams and high beams at the same time
Old May 4, 2001 | 07:17 AM
TicketMeRed '01's Avatar
Post mod: low beams and high beams at the same time
Has anyone been following the fog-lights-on-when-any-other-lights-are-on-mod thread (https://www.f150online.com/f150board/Forum49/HTML/000552.html)?
In it, Vesjas describes a relay from Summit (part no. SUM-G6219) that will enable the low beams when the high beams are activated.
Has anyone tried this? I would be concerned about heat, since it's really the same bulb (just two different filaments), right? WOuld the plastic lens cover blister? Would the bulb life be shortened?
'01 F150 SuperCab 4x4
OffRoad pkg., Tow pkg. (yes, w/ wrong radiator)
SportMasters Hinged Tonneau
Old May 7, 2001 | 02:16 AM
chelly's Avatar
Post
If you're driving with your brights on you're probably on the highway and moving a lot of air over the plastic head light covers, so I wouldn't worry about them so much. What I would worry about is melting your connectors/wires from running so much current through them for a long time.
-'97 F150 Super Cab XLT long bed, 3rd door, 4.6L 5 spd, 3.08 rear end
-Added:
Aiwa CDC MP3 stereo
Sprayed in bed liner
Bug Deflector
Ford Running boards
DRL's
K&N Filter
No Door Chime
Radio Delay
Fog Lights on w/ hi or low beams or parking lts.
Reese concealed hitch
Folding rear hitch step w/ attached brake light.
Pace Edwards Roll Top cover
Old May 7, 2001 | 02:26 AM
Turtle9343's Avatar
Post
not really the same thing here but made me think of something. My buddy has a gmc with the sensor on the dash that turns the headlights on when it senses darkness. he put a dash cover on the dash and covered it up, which fooled it into thinking it was always dark. He also put on the dark headlight covers. So, whenever he was driving the lights would be on. Well, the lights were on, the covers held in the heat and melted the clear original headlight covers. Not a nice sight. Just a little story i thought of while reading. In case you were thinking of buying a gmc, dont use a dash cover and headlight covers at same time. yeah right, what am i thinking?
Old May 7, 2001 | 05:09 PM
phildacf150's Avatar
Exclamation
I think that that part in Summit is for GM vehicles which have seperate bulbs for high and low (4 total). You don't want to burn both of the filliments in the same bulb at one time. The thread you were looking at is to be able to turn on the "fog" lights along with the Parking, or the high beams. Not the High and Low at the same time. I actually ground down some of the plastic in the switch that the switch cam rides along so I could pull out the switch for fog lights with only the parking lights on.
