What Model Bulbs in 2000 4x4 Fog Lamps??!!??
Since ford used so many different bulbs over the years the best thing I can say is take out the bulb and get the number. Without doing this there is no knowing what bulb you have in there.
9005 are the bulbs to use for the factory harness.
I bought 9006 hyperwhite bulbs, and 9006 sockets from discount auto parts. I am going to run power to them direct from the battery, using the factory harness as the trigger to the relay so my stock switch works same as normal.
Boss™
Ordered June 29th, 2000; took delivery Nov. 28th: 2001 F-150 Lariat, Oxford White/Silver Supercab 4x4, Styleside, 5.4L, 7700# payload, Class III Tow, 3.73LS, Skids, Leather Captains, 4W disc ABS, shift-on-fly, keyless.Engine build date: 10-25-00
Modifications:
"Protected by the Owner with his 2 friends, Smith & Wesson" sticker, Westin Chromed Stainless Nerf Bars, ARE LS II bed cover, Bedrug™, Gibson Swept Side Cat Back, K&N filter w/airbox mods, Hyper-White headlight & foglight bulbs, Pioneer DEH-8200R, Ventshades(not on back doors), Hood deflector, Superchip.
Future Modifications:
3" body lift with at least 33's, alarm/pager/auto start system, stereo system
Boss™
Modifications:
Boss96Hog,
Which store had the bulb sockets? I looked when I had my '99 (to add fogs w/o the factory harness), but could not find any. Thanks, Doc
2000 F-150 4x4
4.2L, 5-speed,
3.55 Limited Slip,
reg. cab, short bed,
ORP package (added),
Fog Lights (added),
Super-flip-chipped
...much more to come....
Wife: 2000 Ranger Trailhead Package
2000 F-150 4x4
4.2L, 5-speed,
3.55 Limited Slip,
Fog Lights (added),
Super-flip-chipped
Wish I had bought 9005's but I bought 9006's and lariat4wd is exactly right, the tabs can be easily cut to fit, but the base is much bigger.
I made them work though. Using a bench grinder for the tabs, I also ground around the base and although they were a little snug, they fit!! If they burn out, I'm going with you guys and getting 9005's. Wish I had listened in the first place!
2000 EDDIE BAUER EXPEDITION 4x2
-->Come share my Addiction<--
- Estate Green
- 5.4 ltr
- 3:55 LS rear
- Superchip!
- Airaid FIPK
- Gibson S/S Swept Side Cat Back Exhaust
- Hellwig Rear Anti-Sway Bar
- Edelbrock Performer IAS Shocks
- Xenon Super White Head and Driving Lights
- Clear Corners (installed then removed and reinstalled OEM's)
- Tow Package
- Rear Load Leveling
- Moonroof
- Century Child Seat!
- Front Polyurethane Anti-Sway Bar Bushings recieved, wrong part number
