'98 door switches & pwr door locks
Old Apr 2, 2001 | 11:11 AM
2wise4aGM's Avatar
Question '98 door switches & pwr door locks
I'm thinking (oh oh) about adding a switch to trick the GEM into thinking that the doors are closed. Then the chimes and int. lights will stay off when I need them off, like when listening to tunes with the door open. BTW, although my truck doesn't have factory door locks (adding 'em now) but is the wiring already there ? Too cold here to pull the panels just to check. (I just know sumpin's gonna break !) My Haynes manual schematics don't show the door switches anywhere. Thanks in advance for any help !
'98 f150 XL
ext cab shortbox
4.2 L 5 spd
4x2 3.55
white w/cap
current mods:
Alpine 7861
hidden hitch
NO K&N filter...had to be different
more to come !
Oh yeah, special factory options : Door cracks !
[This message has been edited by 2wise4aGM (edited 04-06-2001).]
Old Apr 6, 2001 | 09:37 PM
2wise4aGM's Avatar
Unhappy
Hey guys ( and gals ! ), throw an old dog a bone here on this one, huh ?
Old Apr 9, 2001 | 12:41 AM
Jimmar's Avatar
Post
Just out of my experience I have found that Ford wires every truck for their top option. Mom's 97 Explorer had wiring for a phone and my 2001 Supercrew has wiring for a CD changer. Both of which wheren't with these options but still the wiring is there. Other than that sorry I am of no use.
2001.5 SuperCrew XLT 4X4
Silver Clearcoat Metallic
Deep Wedgewood Blue (accent)
5.4L V8
Chrome Tubular Step Bars (Ford)
Captains Chairs
Power Moonroof
3.55 LS
6750 GVWR
Class III Towing Pkg
Mods:
Harley Davidson Exhaust
'01 Lightning Head/Tail Lamps
Pioneer DEH-9200r
Boston Acoustic Components & 5X7s
Box Liner (Ford)
Splashguards (Ford)
Bug Defector Doubles as Rock and Sand/Salt Deflector in these snowy Canadian winters
To Come:
17" Rims/Tires
K&N Air Filter
Old Apr 9, 2001 | 11:43 AM
2wise4aGM's Avatar
Talking
Thanks Jimmar ! That's the answer I'm lookin' for. Can always rely on a fellow Canadian for help ! :-)
Old Apr 9, 2001 | 01:40 PM
2wise4aGM's Avatar
Unhappy
Thanks SCCATow, at least I know now. My next question was "how to get the handle off", but you read my mind ! Well, back to my original plan and run the wires after all. (all this so I don't have to lean over to unlock a door !...yeesh)
Old Apr 10, 2001 | 12:22 AM
SCCATow's Avatar
Unhappy
My 97 XL wasn't wired for power windows/locks/mirrors. Sorry to break it to you.
BTW, the door panels are very easy to remove... they just lift UP once you remove the pull hadle, window crank, and two trim pieces (these just pull off). The window crank is a little different... it has an outer trim piece which snaps off partially to expose a Torx screw.... not the usual spring clip affair.
Old Apr 12, 2001 | 11:15 AM
Jimmar's Avatar
Unhappy
Sorry for putting you on the wrong track...
Old Apr 12, 2001 | 08:10 PM
2wise4aGM's Avatar
Wink
No problem Jimmar ! I'll never really know untill I take the door panels off. Thanks everyone for the posts !
'98 f150 XL, ext cab shortbox, 4.2 L, 5 spd, 4x2 3.55, oxford white w/cap
current mods:
Alpine 7861
hidden hitch
more to come !
Oh yeah, special factory option : Door cracks !
Old Apr 17, 2001 | 01:08 PM
MisterP's Avatar
Post
Actually, I think jimmar is right... I don't think that power locks, windows or mirrors are an option on the XL are they? If you are looking at an XLT, it should have all the wiring... the relays and fuses may not be installed but the wiring should be
2000 Extended Cab F-150
4X4 Offroad
Flairside Oxford White
AirRaid FIPK
2001 L Tails
2001 L 3rd Brake Light
2001 L Corners
Pioneer DEH8000, 12 Disc Changer, Custom Amp Rack, Rockford Fosgate Punch 160, Rockford Fosgate 10" SUB. Keyless entry on Drivers door. Brushguard, 2 160 Watt K.C.'s, Duraliner Bed Liner, AVS hood deflector.
