Ford's hidden test feature test your gages
Old Mar 4, 2001 | 04:24 PM
Screwit's Avatar
Thumbs up Ford's hidden test feature test your gages
Ford decided to include a cool hidden feature (HEC Dealer test mode) in the instrument cluster starting in 99. With a simple press of the trip button and turn of the key you could not only test your instrument cluster (gauges), oil pressure and speedo senders, but get a real time digital readout of your speed, tach and other info as you drive your F150.
I tried it and it works there is also a list of trouble codes you can read through the instrument cluster.
http://www.mustangworld.com/ourpics/fcar/dtcodes.htm
http://www.mustangworld.com/ourpics/News/99hec.htm
Old Mar 4, 2001 | 11:51 PM
Talleywacker's Avatar
Suspended For Violation of Vendor Rules
Post
its been done and known...
but thanks for the links!
i didn't know what some of those meant.
Old Mar 5, 2001 | 07:33 PM
GIJoeCam's Avatar
Post
At what point in the process can you safely start the engine?
-Joe-
nevermind... should've read the whole thing first!
Instructions? Who needs 'em?!
98 Explorer (Lemon Law Case in Progress)
'00 F-150, X-cab, 4x4, Lariat, Off-road, Trailer Tow, Holandia Sunroof, built 11/99 picked up 10/00!Clear Corners, Manik Stainless Steel 1-piece brush guard, Custom CB wiring, Uniden PC76-XLW CB radio with K-40 Magna-Mount antenna (for now), 1 set of 165 watt KC Daylighters (for now... more on the way) Custom switch mounting plate and overhead console, Bully Stainless Steel Trailer hitch drawbarw/ 2" stainless steel ball.
List of planned mods: Clear tails, torsion bar tweak, bug deflector, spray in liner, and a tonneau of some sort...
93 Probe GT teal, OE rims painted to match, bone stock drivetrain.
[This message has been edited by GIJoeCam (edited 03-05-2001).]
Old Mar 8, 2001 | 09:59 AM
mattadams's Avatar
Post
awesome I was testing that out on my home last night, I probably drove off the road checkin out my gauge as I was driving along, LOL.
Old Mar 8, 2001 | 10:15 AM
geeky666's Avatar
Question
I thought the oil pressure gauge always reads back the same until the actual pressure drops past a certain point then the gauge drops to zero. If they have the data acquired why don't they use it?
G
Old Mar 10, 2001 | 05:31 PM
mattadams's Avatar
Post
well I think often people get oil pressure and oil amount mixed up. Because you can cram 7 quarts into a 5 quart oil receptacle, but still have low oil pressure, if say you had an oil pump failing or something wrong. Obviously DONT put 7 quarts into a 5 quart receptacle cause your gonna do more damage, but I know that a lot of people get oil pressure and amount of oil confused. I like the guage trick though .
Old Mar 11, 2001 | 12:04 AM
BigBunnell's Avatar
Post
to keep the people of lesser knowledge from taking their truck to the dealer for service every time the gauge would show normal oil pressure fluctuations.
I just remembered that someone on the ford-Diesel website had a way to make the oil pressure gauge show actual readings. It was pretty involved, but several guys did it. Do a search over there if you're interested. www.Ford-Diesel.com
BigBunnell
98 F150 4X4 XLT flareside V6 5sp K&N Flowmaster and some other goodies
[This message has been edited by BigBunnell (edited 03-10-2001).]
Old Sep 3, 2002 | 08:31 PM
BRANRULZ's Avatar
i ran the diag. test, everything seems fine but my oil reading is 000 when the engine is running or when the engine is off, but the oil pressure gauge needle is right between L and H..... should i be worried? and by the way ive driven a lot over the past month (over 3500 miles) and i wont be able to get an oil change in until sometime next week.... whats the most miles you've put on your truck before an oil change? thanx in advanced
Old Sep 3, 2002 | 10:24 PM
MROLDV8's Avatar
Thanks alot Screwit! I printed the article, now I can't wait to try it.
Old Sep 6, 2002 | 05:06 AM
fordblue.I6.300's Avatar
Question hidden dio test oil read out
branrulz
hey mine did the same thing the 000 on the oil pressure
if you find an answer please let me know . I am going past the dealer ship and will ask
on the oil /mileage question the owners manul says 5k miles but I get a sick feeling in my stomic if I go pask 3k between changes
what kind of oil? I know guys that run amsoil synthetics and the go 10k and swear by the stuff
I love my truck to much to try that though maybey after the first 100k
Roy
Old Sep 6, 2002 | 09:11 AM
fade2black's Avatar
I wouldn't worry about the 000 reading. The info said:
Normal oil pressure (greater than 6psi) will display a value between 000 and 176. A low oil pressure or an inoperative engine oil pressure switch (less than 6 psi) will display a value greater than 176.
So a reading of 000 would be normal.
Fade
Old Sep 7, 2002 | 12:03 AM
mjhpadi's Avatar
There is also a test for your radio speakers. If you push buttons 3 & 6 at the same time the radio will do a speaker check and shut down all but 1 speaker at a time.
Old Sep 7, 2002 | 11:01 AM
hmustang's Avatar
The bad thing is if your display is on the blink you can't read all that info.
Old Sep 11, 2002 | 10:46 AM
SCrewTman's Avatar
Be careful when you do this...you can reset your trip odometer...Not a big deal unless you like tracking mileage!
Old Sep 11, 2002 | 07:00 PM
Robdude30's Avatar
Thumbs up
This is really cool. I've know about it for a while, but have just now tried it. It is too bad that this info couldn't be routed to another display so you could have the odometer and the other stuff at the same time.
