DRL Foglights
Old Feb 21, 2001 | 08:00 PM
Badd Andy's Avatar
Lightbulb DRL Foglights
I turned the foglights into DRLs today. I used a relay and found that the #5 fuse in the cab on 2001's is switched on with the ignition(couldn't find one in the relay box under the hood). I cut and hooked the orange/green power wires from the lights to the relay and left the stock black ground wires hooked up.
Badd Andy
2001 Toreador
F-150 Supercab XLT
7700lb, 5.4L, 4R100
Tow Packg, 3.73
DRL Foglite mod
Headlites Relayed
A/C cutout switch
RS 9000's all around
Bug & Wind deflectors
Lund Premier Tonneau
Short rubber antena
98 ANGLER 8.6 Camper
95 Windstar w/replaced head gasket
97 Susuki Bandit 1200
87 Yamaha XT-350
Old Feb 22, 2001 | 04:58 PM
JDF's Avatar
JDF
Question
What is the relay for if you wired it to the fuse box? I was hoping to add additional lights into the grill as DRL's and now I know at least a place to wire into. I was hoping for under the hood also.
Old Feb 23, 2001 | 11:34 AM
Badd Andy's Avatar
Post
The relay relieves you of running a whole bunch of wires to the fuse. With it , you only need one to switch it on and all the other wires(power, grnd, lites)are under hood and shorter. Plus you get the full 14 volts from the battery to the lites directly instead of 12 from the fuse.
