How can I tell if I have keyless entry?
Old Aug 9, 2000 | 09:32 PM
Bud Man's Avatar
Question How can I tell if I have keyless entry?
I recently purchased a 1999 XLT used. It has all available options except for power seats. Is there any way to tell if it is equipped with a keyless entry system? It came with everything else so I was wondering if it had it and the dealer wasnt aware of it. Thanks
99 4x4 XLT
4.6L V8
Torreador Red
AM/FM/CD
All Power
Coming Soon:
Tires, K&N, Dual Exhaust,
Billet, Chip
Old Aug 10, 2000 | 07:19 PM
Dustoff's Avatar
Post
Good question...I am not sure how you would test it to see unless you knew where to look for the keyless remote main box.
Most likely the dealer would have given you two remotes for the keyless entry system if it had it. It is not standard on the XLT and is a $150.00 option.
Have you tried the dealership service department for help??
2000 F-150 XLT, 4x2, 5.4L Supercab, LEV, Superchip, Styleside, Black with silver two-tone, 3.55 rear, class III towing package with heavy duty cooling package, Heavy duty shocks, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, factory leather wrapped steering wheel, FORD bedliner, K&N air filter, mar-hyde rubberized undercoating, Modine climate filtration system , Bugflector II, Mobil 1 oil and filter, Build date 7/00
Old Aug 10, 2000 | 07:59 PM
Don C's Avatar
Post
BudMan
Try going to a Ford dealer, ask them if you can borrow a keyless entry remote. Then see if it will accept a program from the truck, if it does buy it. If I remember correctly you turn the key a few times,till the doors lock and that should program it, but the instructions should be in the owners manual.
1999 F150 4x4 4.6V8 regcab/shortbed
Oxford White with Wedgewood Blue two tone, with Blue Captains chairs
Bullet Cat Back, Superchip, K&N FIPK Intake.
Centerline Saber rims 17x8" with Firestone GTA 275/60hr-17 tires.
Alpine CDA-7845, ADS P640 Amp, Focal Poly Kevlar seperates.
[This message has been edited by Don C (edited 08-10-2000).]
Old Aug 10, 2000 | 08:23 PM
Firezap's Avatar
Cool
If there is a white control box behind the emergency brake on the fire wall with 5 numbers on it you more then likely have it.
GOLD RUSH
'99 F150 XLT SC SB 5.4x2 Harvest Gold
3.55 limited slip
Trailer towing package
In-dash CD player
Ford Beanie bear
Slip on extender mirrors
Powerstop brake controller
Covermaster 1000 topper with wing
BugflectorII
Ventvisors (front&rear)
3 www.f150online.com decals
Ford Lumi Logo
Steelhorse Billet grill
Ford hitch cover
Yellow wire loom
Hyper White head light bulb
Painted to match AVS slotted taillight covers
Ford system 4 alarm
Clear turn signals
"Blazer" strip reflectors under tailgate
<A HREF="http://www.firezap.url4life.com" TARGET=_blank> </A>
<A HREF="http://njf150truckclub.homestead.com" TARGET=_blank> </A>
firezap@f150fanatic.com
firezapper@home.com
[This message has been edited by Firezap (edited 08-10-2000).]
Old Aug 10, 2000 | 09:11 PM
Bud Man's Avatar
Arrow
Thanks for the help. I looked behind the parking brake and I dont have it. My dad said it would only take about 5 minutes to remove if someone didnt want it. Anyways, it looks like im gonna hafta shell out some cash for a new one. Thanks
Old Aug 15, 2000 | 04:25 PM
36racin's Avatar
Post
BUDMAN,
LOOK UP JC WHITNEY ONLINE AND ORDER A CATALOG FROM THEM. A COWORKER BOUGHT A KEYLESS ENTRY SYSTEM FROM THEM FOR HIS MINIVAN FOR $30 OR SO DOLLARS AND IT JUST PLUGGED INTO THE FACTORY HARNESS PROVIDED FOR HIS VAN. GIVE IT A TRY ITS ALOT BETTER THAN THE $150 OR MORE THE DEALER WILL WANT. ALSO CHECK LOCAL RADIO STORES THEY HAVE SIMULAR KEYLESS ENTRY SYSTEMS FOR THE TRUCK ALSO. GOOD LUCK
