Transponder
Old Jul 29, 2000 | 11:28 AM
98fword's Avatar
Post Transponder
I'm going to try to post a picture for those of you who have ever wondered what the transponder in your key head looks like.
[img]//www.nvo.com/natl/nss-folder/pictures/texas01.gif[/img]
It's not an extremely detailed picture. On the left side is a very fine coiled copper wire around a rod. This produces just enough current to power the circut board on the right when it gets a signal from the vehicle's computer via the small wire antenna that is routed up the steering column and wraps around the ignition lock housing. Once the circut board is energized it sends it's encripted code back to the computer through the same antenna. The transponder doesn't have it's own power source. It gets just enough power from the radio signal from the computer to send it's code back one time. It will remain dormant until it recieves a signal the next time. Pretty cool, huh?
Oh, these things are about 15/16" long and just over 1/8" in diameter.
98 F-150 XLT 4X4 ORP Super Cab Short Bed, 4.6, Auto. Magnacharger supercharger. Superchip, Gibson sing. cat-back, 80/100w German head lamps. Warn HS9500i winch with semi hidden mount. Wrangler dual battery kit with red & yellow top Optima batteries. Torsion bars cranked up 2 turns. Needs one more door.
[This message has been edited by 98fword (edited 07-29-2000).]
Old Jul 30, 2000 | 12:58 AM
max mitchell's Avatar
Cool
Thanks for posting this; I like to know these things.
2000 F-150 XL,RC,LB,5.4,4R70W,3.55LS,
Class III tow/Payload #3/Convenience pkgs.,
4-wheel disc/ABS,Chestnut/Parchment 40/60,
Ford bedliner & gas/wheel/spare locks,
3" cold air box modification,Superchip,
Dynomax ultra-flow welded 3" cat-back.
