I know i know the fog light mod
Old Jun 9, 2010 | 12:42 AM
znhunter's Avatar
no there is no jumper i have the fogs working when the parking lights/SIDEMARKER LIGHTS/ i want to to have just the fogs working when in the off position like in the below http://www.fordf150.net/photos/showp...5/ppuser/28136.I do i wire this add a fuse up to my radio fuse ?can you make a digram for me sorry this is taking me so long to get i appreciate your time i really do!!
Old Jun 9, 2010 | 12:43 AM
znhunter's Avatar
how do i wire this add a fuse up to my radio fuse ?can you make a digram for me sorry this is taking me so long to get i appreciate your time i really do!!
Old Jun 9, 2010 | 08:05 AM
SSCULLY's Avatar
Use a meter to find which side is the hot in Run / Accessory position power on the radio fuse ( the other side of the fuse is to the radio ), by pulling the fuse out, and checking the socket on both sides.
1 side will have power with the fuse out, the other will not have power ( that is the radio side ).
Install the add-a-fuse in the radio slot, with the wire pointing towards the side that did not have power.
Install the radio fuse in the lower of the 2 fuse slots on the add-a-fuse, install a 1 A fuse in the top, once you are done splicing this to your headlamp switch.
This is a diagram of installed correctly, and incorrectly
The new circuit ( the wire with the crimp ) is what is wired to the white w/ black stripe wire on the main headlamp switch. Pull CJB Fuse # 27 ( you don't want to feed power back into the MFS ).
That is all there is to it, anytime the radio can work, the fog lamps can work ( as long as you did the ramp modification correctly ).
