SRS light on?
Old May 13, 2000 | 02:23 AM
Z71killer's Avatar
Red face SRS light on?
Recently, the little orange light next to the battery voltage readout on the display illuminated. Usually, it would go out after you start the engine up, but it has stayed on. I disconnected my battery and hooked it back up hoping the fault would reset and go out, but the light is still on. The light has a symbol of a passenger with a seat belt and an air bag. Anyone have any ideas? Thanks.
98 F150 4x4 ORP 5.4L Super Cab XLT, Loaded. 4" Trailmaster Suspension Lift, 35" BFG Mud Terrains, 16.5 x 9.75 Weld Racing Super Single II wheels, Stull Billet Grill and Bumper Insert, Custom 40 series Flowmaster Exhaust out the back, K&N Filter Kit, Super Chip, and a Ford Hitch Cover to top it off!
Old May 13, 2000 | 10:37 AM
Dustoff's Avatar
Post
This is your air bag readiness light.
On pg 8 of the 1998 owners manual..it states "If the light fails to illuminate, continues to flash or remains on, have the system serviced immediately."
It could be just about anything in the SRS...I would have it looked at before it un expectantly deploys or fails to do so when you need it!
2000 F-150 XLT, 4x2, 5.4L Supercab, Superchip, Styleside, Black with silver two-tone, 3.55 rear, class III towing package with heavy duty cooling package, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, factory leather wrapped steering wheel, Pendaliner bedliner, K&N air filter, rubberized undercoating, cabin filtration system, Bugflector II, 5W-30 Mobil 1, engine build 10/4/99
[This message has been edited by Dustoff (edited 05-13-2000).]
Old May 13, 2000 | 10:43 AM
Dustoff's Avatar
Post
Also, Chilton's 97-00 F-150 manual states on pg 6-7 that:
"Any fault detected by the diagnostic monitor will illuminate the lamp and store a Diagnostic Trouble Code (DTC)."
Pg 6-8, "If at any time, the air bag light indicates that the computer has noted a problem, have your vehicle's SRS (supplemental restraint system) serviced immediately by a qualified automobile technician. A faulty SRS can cause severe injury or death."
I checked the NHTSA web site to see if anyone had complained about the 98 model year F-150 air bag system...sure enough..plenty! MANY failure to deploy complaints.
http://www.nhtsa.dot.gov/cars/proble...n/compmmy1.cfm
