door ajar
Old Feb 8, 2000 | 06:23 PM
king's Avatar
Post door ajar
My door ajar alarm (and dome light)stays on even after closing the driver's side door when it is warm in the cab. If it is cold in the cab the problem goes away. Only the driver's side door causes the problem. Is there a fuse I can disconnect to turn off the constant BONGING until I can locate the problem. I think the door ajar alarm relay is the fault. Anyone else had this problem?
(1997 150)
Old Feb 8, 2000 | 08:35 PM
Dustoff's Avatar
Post
king--
Welcome to F-150online!
This topic seems to be common lately. If I remember correctly...the problem seems to be a faulty switch that is not being triggered when the door is closed.
Try a <search> on this topic for more info...there are some detailed discussions on this.
Good luck!
2000 F-150 XLT, 4x2, 5.4L Supercab, Styleside, Black with silver two-tone, 3.55, class III towing package with heavy duty cooling package, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, Pendaliner bedliner, K&N air filter, rubberized undercoating, cabin filtration system, Bugflector II, 5W-30 Mobil 1, engine build 10/4/99
Old Feb 9, 2000 | 03:13 AM
jr's Avatar
jr
Post
Spray inside the door latch with some carb or brake cleaner (the part that hits the strike) this is where dome light switch is, this worked for me. If that doesnt work there is a relay in fuse box you can pull, I believe its on the top left of fuse box. If you pull relay door ajar light will stay on but dome light will not.
Old Feb 25, 2000 | 09:07 PM
Joules's Avatar
Question
The same door ajar problem has just occured on my 97 F150 XLT. Did you fix the door switch? and how?
Old Feb 27, 2000 | 10:32 AM
king's Avatar
Post
If you spray WD-40 into the door latch assembly on the door edge and really soak it good your door ajar problem should go away. I went for weeks thinking it was the alarm relay sticking but this simple fix (thanks to someone else on this board)was all that was needed.
Old Mar 7, 2000 | 08:36 PM
Ryno's Avatar
Post
My 97 XLT has been doing this for about a month also. Ill try the WD40 trick and let you know if it helped me out. Thanks to all for thr info.
Ryno
Old Mar 7, 2000 | 10:43 PM
Sycoholic's Avatar
Cool
I've done the WD-40 trick at work a couple times,and saved people repair bills, and have done it on my brothers Ranger. Since spraying my brothers Ranger several months ago, he has had NO problems with it. I reccomend spraying the door latch periodically with WD. Like every oil change would be a good idea, and it will keep it working like new longer.
1997 F-150, 4.6, automatic, Dark Toreador Red, Supercab, Flareside, 4X4 Off-Road, Towing Package, Ford hvy dty rubber floor mats, Kenwood 10-disk cd changer, Ford bugshield, Chrome Grizzly Wrap Around Push Bar with 2 KC 100w Daylighters, Ventshades, Ford bedliner, Lund Premier tonneau cover, cab and bed professionally undercoated, Code Alarm Sure Start RVS remote starter, Ford alarm, Realistic CB with Wilson Little Wil antenna and Astatic power mic, ported MAF sensor, and Lots of TLC!! (Besides being an F-150 nut, I am a Ford auto technician.)
Old Mar 14, 2000 | 07:13 PM
Ryno's Avatar
Post
Thanks guys the WD-40 worked great for me!
Ryno
