Warning indicator
Old May 18, 2010 | 10:08 AM
Jackp212's Avatar
Warning indicator
Every so often I get a audible and message in the dash saying Check braking system, ABS and the traction control all light up. the brakes feel fine and the fluid is full. If I shut the truck off and re start it goes away. Has 3000 mi and has been back twice for repairs under warranty. First was the power window motor drivers window, and the 4x4 vaccum pump with the hub and bearing. Now this... think I got a unit assembled on a fri or mon ... anyone else having these problems, 2010 screw.
Edit/Delete Message
Old May 18, 2010 | 11:35 AM
SSCULLY's Avatar
Rather than posting this a second time in this forum,
https://www.f150online.com/forums/el...-traction.html
try a search in the 2009-2010 forum
https://www.f150online.com/forums/20...s-service.html
Looks like it has happened to other members, and you will be covered under warranty.
Old May 19, 2010 | 07:29 AM
Jackp212's Avatar
Thanks, still learning how to navigate the system
