ABS & RSC Lights on - Service?
Old Jan 31, 2010 | 07:00 PM
dainessmith's Avatar
Both the ABS and RSC lights came on this afternoon. In the manual this sounds like a trip to the dealer.
Has anyone had any problems with this? Cost to fix?
It's on a 09 F150 4X4 Lariat. I'll probably be making an appointment tomorrow, but thought I would check here first.
Old Jan 31, 2010 | 07:05 PM
Dont know what the problem would be but take it in since its under warranty, it wont cost you a penny to get it fixed
Old Feb 1, 2010 | 08:08 AM
Deano-FX4's Avatar
yes
Old Feb 2, 2010 | 09:15 AM
xlted's Avatar
This happened to me a couple of weeks ago. The dealer had to replace a sensor in the right rear wheel. No idea on the cost, it was covered under warranty.
Old Feb 2, 2010 | 01:49 PM
jvos's Avatar
Yes, known problem - faulty ABS sensor. yes, its covered by warranty. Service takes about an hour.
Old Feb 2, 2010 | 05:45 PM
The truck was in today and as noted earlier the problem was the RH rear ABS sensor. The assembly was replaced under warranty and is now back to normal.
I'm not sure if this is a general issue, or just coincidence...
Old May 19, 2010 | 07:33 AM
Jackp212's Avatar
Every so often I get a audible and message in the dash saying Check braking system, ABS and the traction control all light up. the brakes feel fine and the fluid is full. If I shut the truck off and re start it goes away. Has 3000 mi and has been back twice for repairs under warranty. First was the power window motor drivers window, and the 4x4 vaccum pump with the hub and bearing. Now this... think I got a unit assembled on a fri or mon ... anyone else having these problems, 2010 screw.
Edit/Delete Message
