97 Ford Blowing fuse#29 wich is a 5 amp
My 97 F150 keeps blowing the 5 amp fuse on the inside fuse box and it takes out the complete dash board gages. Some times it has worked for a month and then it did it twice in the same day. Had auto light and gage light off. Turn signals work and flash as normal. All other lights and bells work. Im thing it might be a relay shorting to ground. The fuse # is 29.Thanks for any help!!
Last edited by diswilldo; 03-19-2010 at 10:07 AM. Reason: SSCULLY was so right and it's fixed now!!!!!
on
Take a look at the base of the gear shift lever for a wire that is bare. This is at the end of the gear shift lever tube, under the steering wheel column cover.
Fuse #29 controls the overdrive button, as well as the instrument cluster items. After time, some will develop a bare wire in the base, and cause a short.
