Hello everyone,
Old Jan 4, 2010 | 10:23 PM
strokwilliam's Avatar
Hello everyone,
My name is Tony (Mobile, Al FFinest),
I have a 2004 Lariat Supercrew 5.4 with 130,000 on her, I'm okay with the annoying *** tapping that the dealership says they can't do anything about, can anyone help me with the sudden loss of cruise control that the dealership can't seem to fix????????????????
Thanks,
Tony
Old Jan 4, 2010 | 11:09 PM
SSCULLY's Avatar
Did you change you CHMSL ( Center High Mount Stop Lamp ) or tail lamps to LEDs ?
Old Jan 8, 2010 | 04:17 PM
No I didn't change the CHMSL, my lights are factory!!
Old Jan 8, 2010 | 04:23 PM
SSCULLY's Avatar
Do the radio controls & horn still work ?
Old Jan 11, 2010 | 09:38 AM
Thanks for responding SSCULLY,
The horn and radio work fine,I had a small problem back here at the beginning of winter ,in which my throttle would cause me to shut down, my airbag light would come on and stay on,my engine light would come on , come to find out it was my battery going dead so I replaced it and haven't had those problems since, it's just the cruise want come on!!
Old Jan 11, 2010 | 09:45 AM
SSCULLY's Avatar
Radio or radio controls work ?
Old Jan 17, 2010 | 11:40 AM
yep, my radio control /controls works great, the cc button doesn't even light up on the dash or engages!!!!!!!
Old Jan 17, 2010 | 11:52 AM
JackandJanet's Avatar
AND, you've verified that ALL your brake lights, including the 3rd one, are working fine?
- Jack
Old Jan 18, 2010 | 11:06 AM
Yes, everything works , the last few days my airbag light has been flashing on and off too!!!!!!!!!!!
Old Jan 19, 2010 | 08:37 AM
SSCULLY's Avatar
The only other 2 things that can be checked ( without a IDS ) are :
1. The Cruise Control switches
2. The Cruise Control Disconnect Switch.
If the CC disconnect switch is always on, the CC won't set.
The Cruise Control Disconnect switch is mounted on the top of the brake pedal, with 2 wires to it.
You can unplug the connector, and check the switch with a meter, set to ohms.
With the brake pedal off, the switch should read open, press on the brake, and the ohms should drop to 100 or less ( less thatn 100 if your meter has new batteries in it ).
