off road lights
Old Dec 19, 2009 | 06:43 PM
RoushRich's Avatar
off road lights
light on switch comes on. I hear relay click but no lights what should i check first?
Old Dec 19, 2009 | 07:16 PM
SSCULLY's Avatar
Is this a new install, or an existing correctly functioning install, that now has a problem ?
Old Dec 19, 2009 | 07:48 PM
RoushRich's Avatar
New install
Old Dec 19, 2009 | 09:53 PM
SSCULLY's Avatar
If the relay is a standard Bosch type automotive relay, you can start by pulling the relay, and jumpering the normally open contacts ( red line in the drawing below, make note of the pin orientation ).
This should illuminate the aux lamps without the use of the switch.
If this does not work, check the fuse to the battery ( should be on terminal #30 ), and the connections to the aux lamps ( should be on terminal #87 ).
Old Dec 20, 2009 | 12:58 AM
thejake1989's Avatar
have you check the ground for the lights yet?
Old Dec 20, 2009 | 06:18 AM
RoushRich's Avatar
Should the black wire from the lights ground to batt or just ground to truck some place?
Old Dec 20, 2009 | 09:54 AM
Shouldn't matter either way but I'd double check all three grounds. It seems like the on for the switch and relay are good since you said they switch lights up and you hearthe relay click.
Old Dec 20, 2009 | 12:11 PM
SSCULLY's Avatar
The battery is fine, the fender ground lugs where the headlamp ground is also good, but harder to get to on the 2004-2008 MY, from what my mind is recalling right now.
Probably shouldn't play the recall game right now, I don't have enough coffee in me yet.
