Could use some help im confused
Old Dec 1, 2009 | 11:56 PM
mav015's Avatar
ok so i just went out to my truck to go home from a buddies i click the unlock button head lgiht dont come on like normal on the yellow lights turn on weird. i start the truck and neither of them turn on, i flip it from auto to manual head light on the switch. The yellows go on and the interior lights go on but neither head light goestays on on auto and manual. As im driving i figure ill see if the high beams work, so yes the highs work on both but neither light work on normal head lights. Can anyone help me with this problem? I would like to drive my truck at ngiht so i figure maybe ill start by looking at the fuses? Im very confused i havent ever seen this before can anyone tell me what going on with my truck?
thanks yall
Old Dec 2, 2009 | 12:07 AM
no-mams's Avatar
check the light bulbs, i think they are the 9008. Its a single bulb for both low/high beam.
Old Dec 2, 2009 | 12:16 AM
SSCULLY's Avatar
Not sure what you mean by the parking lamps turn on weird.
If I read it correctly, when you turn the main headlamp switch to the head position, the parking lamps and the interior lamps came on at the same time ?
Good place to start is with checking the fuse for both the L & R low beams.
To test the fuses, you need to have the main headlamp switch in the head position, and the MFS pulled back, else when you put the meter on each side to of the fuse, it will be dead. test 1 side to ground with a meter, then check the other side to ground. This also will test the MFS function for the low beam.
If this tests good, next to do the same test on the bulb connector. If you have power there, same as no-mams posted, new bulb time.
You have auto lamps.
Any modifications ? ( HID, fog lamp mod, etc )
Do you have DRLs ?
Old Dec 2, 2009 | 12:18 AM
mav015's Avatar
i was thinkin about that hwo would high beams work and not low then?
and i both at the same time? thanks man ill try that first i guess
Old Dec 2, 2009 | 12:23 AM
mav015's Avatar
stock head lights from factory the parking lights are on in all positions but not the head lights. can u tell me where to find the fuse because im at school right now and not at home where all my tools and manuals are
i have aftermarket fogs but they are wired totally separate so those shouldnt effect it and ive had them on for about 30,000 miles already
thanks for the help yall
Old Dec 2, 2009 | 08:39 AM
mav015's Avatar
can anyone tell me where to find the fuses because im at school right now and not at home where all my tools and manuals are
thank yall
Old Dec 2, 2009 | 10:13 AM
SSCULLY's Avatar
The fuses for the low beams are 2, and another 1 for the high beam for a total of 3 fuses.
Right side low is fuse #23
Left side low is fuse # 25
High beam is fuse # 35
If you need a copy of the manual, you can download the PDF from Ford :
https://www.fleet.ford.com/maintenan...ls/default.asp
Always good to have this in addition to the paper copy, so you can search for a keyword, and find stuff quicker.
The fog lamp question was about the change for the factory operation, does not apply to your install.
The fuse panel is in the passenger side kick panel where the fuel inertia switch is at. You will see a finger hole to pull the panel towards the back of the truck ( pivots like a door on the front tabs ), and then you will see the cover on the fuse panel. Fuse panel only has the location number map on it.
Old Dec 2, 2009 | 05:07 PM
mav015's Avatar
it wasnt the fuses but both head lgiths went out at the same time
isnt it kinda weird for both head lights to go out at the same time?
Old Dec 2, 2009 | 06:41 PM
SSCULLY's Avatar
No, that is in the column for possible but not probable.
Could also be you were driving on 1 headlamp for a few days, the aftermarket fog lamps were covering this up ( light fill ).
If you think about it, theoretically they should always go out at the same time, at least within hours of each other.
They run the same amount of time, at the same wattage with the same voltage levels, and the given AMP draw for the voltage level they have at the time.
The fact that lights can go out at different times, most of the time is the variance in the manufacturing of the bulb.
I just replaced my 2nd driving lamp bulb, the other bulb was replaced 5 or 6 months ago, and they were in a 2 pack of bulbs, installed at the same time.
Old Dec 2, 2009 | 10:02 PM
mav015's Avatar
thanks man yea i change them to the silver stars they are very nice thanks for the info boss
