Battery Question
Old Nov 27, 2009 | 10:29 PM
shawneeman's Avatar
Battery Question
The other day I was washing and cleaning my truck. I put the key in the 'run' position instead of the 'accessory' position to run the factory radio while I worked. I then moved it from the yard where I was washing it to the drive to finish vacuuming and do the wipe down inside. It started fine. I left it in the 'run' position again so I could listen to the radio with the door open and not hear the key chime, like my neighbor was doing across the street. I usually flip the door latch with a screw driver so it thinks the door is closed, but not this time, duh.
Went to start it later in the pm when I was done and it would not start. The gauges went crazy and it chattered the starter like a dead battery. Then the horn went crazy. Honking and honking like a code of some kind. It was almost like I had an alarm but as far as I can tell I have no alarm installed.
I had to disconnect the neg battery cable to get it to stop. I plugged in the battery charger for a while and it started later.
I started it today and it was fine. I have been reading through the posts and I had a lot of symptoms of a dying battery with the gauges going weird and all. It is the original battery with about 20,000 miles on truck. I seem to have the 'signs' of a dying battery figured out so I will keep an eye on it for a while.
Does anyone think it is time to change it or just wait a bit longer?
Old Nov 28, 2009 | 02:23 AM
08stx4x4's Avatar
I think I remember my gauges going crazy too last time I killed my battery. I left a laptop plugged in over night and when I came back the next day it was dead.
My horn didn't go off and nothing abnormal happened with my lights. So not sure about that part.
Old Nov 28, 2009 | 03:33 PM
JackandJanet's Avatar
I think I'd at least get the battery load tested. You really don't want it to die when you're out in the boondocks and no ones araound to give you a jump start.
- Jack
Old Nov 28, 2009 | 04:15 PM
shawneeman's Avatar
Yes I think that a load test and cell check are in order to understand the health of my battery.
Old Nov 28, 2009 | 05:00 PM
When you use "run" instead of "acc" then you are turning on all the computers and modules in the truck, instead of just the windows/radio etc, so the battery will die faster in run
Old Nov 29, 2009 | 01:49 AM
shorse's Avatar
turn off the heater if you have it in run also... that'll drain the battery too..
having the horn go off, i have no clue why... the computer must not have liked the low voltage...
Old Dec 2, 2009 | 12:37 AM
shawneeman's Avatar
Guess what. I do have an alarm! It seems that for the last two years that I have owned my truck, the alarm system has been in valet mode! Some how I managed to flip the ignition to take the alarm system out of valet mode the other day when I was cleaning my truck.
I found in the glove box a small guide on the factory alarm system buried in there. Any way, read it over a couple of times and figured out what happened.
I like valet mode much better than armed mode. At least I can arm it when I want to or feel I need to.
