Trouble codes
Old Sep 30, 2009 | 11:16 AM
willbur283's Avatar
Trouble codes
I ran across a diagonstic screen that gave the following codes:
D900
9204
E013
D950
9201
Does anyone know what they mean?
Old Sep 30, 2009 | 11:43 AM
JackandJanet's Avatar
No idea at all. The lists I know about have 4-digit codes starting with P, B, C, and U. Nothing beginning with D or E and nothing without a starting letter.
- Jack
Old Sep 30, 2009 | 12:03 PM
SSCULLY's Avatar
Are those from the DTM on the Instrument cluster ?
If so, those are hex displayed 16 bit codes.
Part of them can be from items like no oil pressure ( usually the DTM is run position with the engine off ), or other similar when the key is in the run position, but the engine is not running ( truck expects the engine to be running in this position ).
Do you have a CEL icon illuminated on the cluster ?
If so, get a code reader, as the hex code id kind of hard to convert to a 16 bit and figure out what the actual DTC is.
