Garage Door Opener
Old Sep 27, 2009 | 08:48 PM
Tahoe Dave's Avatar
Garage Door Opener
My 2006 Mk Lt (F150) is equipped with the garage door opening feature. So are all of our other vehicles. For some reason, the truck's opener doesn't work very well. It is extremely directional and has to be very close to the garage door in order to work.
It feels like the signal is too weak? Any thoughts or suggestions?
Thanks in advance
Old Sep 28, 2009 | 11:40 AM
JackandJanet's Avatar
Thanks in advance
None at all - I seem to have the same "problem". I have to get pretty close to my garage door too with my truck before the homelink button will do anything. I also have to hold it down for a significantly longer time than I do with the little handheld transmitters that came with the openers.
- Jack
Old Sep 28, 2009 | 11:52 AM
SSCULLY's Avatar
Not sure if you have your antenna on the opener hanging straight down, and where you paired your open from.
I do notice I have to press the button a bit longer than the Chamberlin remote, but I can open the door from the end of the driveway, ~ 30' away.
Might want to check that you have the opener antenna hanging straight down.
Also, what is the construction of garage door header ?
I have a 2 2x12 and plywood header with a W6 I beam above that ( for supporting steel in the ceiling, but do not have a steel plate in line with the antenna, that is all wood to the antenna.
Hard to see with the lighting, but the antenna is pointing straight down on the opener, and the line of "sight" is only through wood. The W6 I beam is in the drywall return beam in the ceiling ( you can see the steel loop that is drilled and tapped into it for a chain hoist to get very heavy stuff in the back of the truck.
Old Sep 29, 2009 | 10:38 AM
Tahoe Dave's Avatar
Thanks for the reply, The header is wood so I don't believe that is interfering. I will revisit the antenna, perhaps add to its length. At the end of the day, I suspect it's a "weak" transmitter in the truck
Old Sep 29, 2009 | 01:03 PM
Adding to the length MAY help, but I suspect the "stock" length is related to the frequency of the transmitters. You might try doubling it as opposed to randomly increasing the length.
One thing Janet has noticed, if I don't park my truck in quite the right spot, it seems to effect the range of her transmitter (my truck is beside her car). If I get it right, her transmitter has close to a 300 ft range. So, reflection seems to be a factor in all this.
- Jack
