Keyless Keypad
Old Aug 19, 2009 | 05:24 PM
Dakotah's Avatar
Smile Keyless Keypad
My keypad recently stopped working, so I assume I am looking at replacing it. I have a 2000 F150 Lariat Ext. Cab 5.4 Will a 2001 F150 Keypad work on my truck? I have one of those available to me.
Old Aug 19, 2009 | 05:28 PM
SSCULLY's Avatar
I just checked the PN from my 2001 install ( yL3Z-14A626-AA ) and the part is listed as :
Front door - Lock and hardware - Keyless lock pad
Keyless lock pad - Regular & super cab 2000 - 2004
The '04 MY is only for the L and Heritage models, the other '04 models were the New body style. Just to be clear on the '04 notation.
Old Aug 19, 2009 | 08:43 PM
Dakotah's Avatar
Smile key pad on 2000 f150 Lariat
If I replace my key pad with one from another vehicle, do I have to know the code off the other truck, or will it work with my code once I install it.?
Old Aug 19, 2009 | 10:01 PM
SSCULLY's Avatar
It is the same one on the RAP in your truck, does not change, unless the RAP is changed.
BTW : Don't make a new thread each time, replying to the same thread is fine, it is all on the topic of the keypad swap, best to keep it all together.
Old Aug 19, 2009 | 11:20 PM
Dakotah's Avatar
ok got it. And thank you very much for the quick reply. I guess if I managed to change the lock actuators, (Im a girl) I can manage the keypad. Right
Old Aug 20, 2009 | 09:14 AM
SSCULLY's Avatar
Regardless of gender, if you replaced your lock actuators, this will be a cake walk.
Here is a thread on installing the keypad ( if it was not on the truck ), that might help with the swap out
http://www.svtlightnings.com/svt/how...ad_install.htm
Old Aug 20, 2009 | 11:38 AM
Dakotah's Avatar
Thanks again for the quick reply. You have been a great help. I will get started. I do have a key pad on there already, it just isnt working anymore.
