OEM remote starter not starting...
Old Jul 29, 2009 | 10:52 PM
IH8ATTN's Avatar
So I looked in the manual it says if the light (the red indicator light on the dash) flashes once every 4 seconds that means the remote starter has been disabled. So I called 1-800-Ford-Key and the tech is telling me to turn the toggle switch the other way...there is no toggle switch, atleast from what I see....but there is a small push button. Anyways when i press the lock then the blue starter button it goes through the cycle 3 times (lights on primes the fuel) but no start.....anyone know how to undisable the remote starter because the tech sure didn't....I may call back tomorrow and hope to have a competent person to talk to tomorrow...any input would be greatly appreciated!
Old Jul 30, 2009 | 10:29 AM
SSCULLY's Avatar
What were the symptoms before you noticed the LED, and what did you do with the person on the phone ?
Which version is the RMST ?
Old Jul 30, 2009 | 03:32 PM
mtylerb's Avatar
Just a shot in the dark, but if you touch a programmed key to the key cylinder, does the remote start work? That's exactly what mine does and I found the problem to be that the bypass module, I have, isn't working properly. I just haven't gotten around to getting a replacement module, yet.
