Leds in switches
Old Jul 2, 2009 | 08:57 PM
RebColonel's Avatar
Leds in switches
Has anyone ever changed the color of the lights in their window,door lock and cruise control switches?
Old Jul 2, 2009 | 09:13 PM
thejake1989's Avatar
theres a link in this thread to a write up on how to do the switches
https://www.f150online.com/forums/ar...r-97-03-a.html
Old Jul 2, 2009 | 09:35 PM
RebColonel's Avatar
Thanks that is an excellent how to for the gauge cluster and hvac panel, but it doesn't cover the light swiches that I need to know about.
Old Jul 2, 2009 | 09:41 PM
If you read through it there is a link to an article on another site. I can't tell you what page because I changed my settings to show more posts on each page and put the max so its on page 2 for me. Its in there
Old Jul 2, 2009 | 10:04 PM
RebColonel's Avatar
Thanks I'll keep looking.
Old Jul 3, 2009 | 07:06 AM
SSCULLY's Avatar
The other option is to use Jack's how to on repairing the LEDs in the switch.
https://www.f150online.com/forums/ar...-switches.html
This is just showing the switch taken apart, and where to hit them with solder, but if you desolder them, and install new LEDs, should be good to go.
In case you did not get to it, the link to the door switches
http://www.fordf150.net/forums/viewtopic.php?t=63465
I think there are a few threads in the 2004-2008 Forum on this topic ( not 100% sure )
Old Jul 3, 2009 | 05:39 PM
RebColonel's Avatar
Thanks, the link to the door switches is what I needed. Gathering up the parts needed is the aggrevating part.
Ok you can keep your job now!
Old Jul 3, 2009 | 08:39 PM
JackandJanet's Avatar
Good luck on this! Those flippin LEDs are almost microscopic! (And, I'm not kidding)!
You're going to need some pretty high magnification just to see what you're working on and a very tiny soldering iron point - with a steady hand. Probably will need at least a third hand too.
Please try to take pictures if you do this. We'd all like to see how you do it.
- Jack
Old Jul 7, 2009 | 07:24 PM
shayden7's Avatar
I did it on all my controls, and switches !!
Old Jul 7, 2009 | 10:21 PM
Good on you! That's pretty "close" work!
- Jack
Old Jul 8, 2009 | 07:16 PM
Charger77's Avatar
Didn't happen unless you put up pictures. Seriously though, how long and how hard was it to install? I think I've got everything I need, but I'm intimidated/short on time it seems like.
Old Jul 8, 2009 | 07:42 PM
shayden7's Avatar
it was a pain!!! the leds are tiny !! also time consuming, but worth it !!!
Old Jul 8, 2009 | 09:36 PM
Could you at least list the tools you used? Maybe take a picture of anything that is not "obvious"? Oh heck - just take a picture of everything - a picture is worth a "whole bunch of words"!
- Jack
Old Jul 29, 2009 | 10:19 PM
shayden7's Avatar
smt leds, soldering iron, solder, desoldering braid, a small flat screwdriver, and a butt load of patience !! word the the wise leds are heat sensitive so you have to be quick. The smt leds are 2 small 2 heatsink !! sorry no pics
