wiring fog lights to headlights?
im pretty sure it was done correctly i didnt end up having to do all that bc i went to autozone and found out that my projector headlights came with a thing that you just have to do that pigtail thing you talked about then i wired the foglights and my headlights to that. and the projector headlight thing had a connection made to connect to my stock headlight plug....
let me know if you dont get that lol sorry its hard to describe
You did 2 changes at one time, and have a problem, we need to step back and make sure the headlamps part was done correct, 100% sure it is correct.
So you know the projector headlamps work then.
The HID kit, does the ballast have a trigger circuit, or only the input voltage to turn it on and off ?
If the ballast does not have a trigger voltage, it is going to look like this when we are done ( these are for headlamps, but similar install )
